Suggestions on where to go for a fluid flush?
Old Jul 5, 2018 | 05:59 PM
AtlantaBran's Avatar
Default Suggestions on where to go for a fluid flush?
Check Engine light came on and I took Shaka (my cars name) to the local dealership. In addition to needing to replace the fuel pump control relay pack (thanks tighed1), the diagnostic also mentioned a complete fluid flush. The notes mention a fuel induction service, break fluid flush, differential service coolant flush and power steering fluid flush. My service guy, not sure if he was telling the truth or trying to scare me, said that I should be careful about going else where - especially for the power steering fluid. Hoping you guys can help me out regarding where to go or what to do. I was thinking the local Jiffy Lube (or similar ??) or is this something that I can do myself? Thanks for any help.
Old Jul 5, 2018 | 06:10 PM
Default Re: Suggestions on where to go for a fluid flush?
How many miles on this car? The dealer will cost you a small fortune.
I cannot say there is a differential cooling system, oil only.
Power steering service is just sucking out the old and adding the correct fluid, no big deal.
Putting it bluntly the dealer wants to rob you. You should be sble to do it all yourself and if the miles are not too high you can skip some fluid changes.
Old Jul 5, 2018 | 06:11 PM
It is totally something you can, and should do yourself, NOT a dealer or for certain not Jiffy Lube,
I did all the above my self.
Old Jul 5, 2018 | 06:38 PM
89K. Yep, they wanted about $900 for just the flush.
Old Jul 5, 2018 | 09:35 PM
velociabstract's Avatar
Power steering fluid flush? Never changed it on any car I've owned, ever. As far as I understand it's just designer hydraulic fluid similar to transmission fluid, which will work fine. I'd check the oil level in the diff and fill as needed only, unless you've been racing regularly. Changing the brake fluid is easy enough to do yourself. If it's never been done before in 14 yrs. I'd do it. I don't know what a fuel induction service is. They're offering mostly needless service to give you piece of mind after planting seeds of doubt.
Les
MRethman
Feb 15, 2014 07:09 PM
ibedoughboy
17
May 7, 2012 09:09 PM
pancakesth
Nov 8, 2010 04:03 AM
murtazanooruddin
May 31, 2010 08:51 PM
SRT6_Roadster
17
Apr 25, 2010 05:40 PM
