Pcm interchangeablety
Old Jul 13, 2018 | 05:03 PM
Rexhicks's Avatar
Default Pcm interchangeablety
PCM? If you change pcm with exact part number, does it need to be flashed, to operate properly!
Old Jul 23, 2018 | 08:49 PM
Rpaczan's Avatar
Default Re: Pcm interchangeablety
My understanding is the powertrain control module needs to be unlocked before it can be programmed by a DRBiii or DAS Star tool. It’s programmed with VIN, secret pin for the Skreem, country etc.. There are companies that will repair the original PCM for $250-300. Some companies also offer cloning of the PCM to another working/reconditioned PCM....that appears to be more expensive $500-800 range.
Old Jul 24, 2018 | 12:12 AM
Rexhicks's Avatar
Thanks for the info, sounds just like the PCM I purchased off the internet. I guess I'll focus on my original PCM it cranks, the injectors are delivering fuel, but no Spark! Thanks. Rex
Old Jul 24, 2018 | 11:01 AM
Did you check the RCM?
Old Jul 24, 2018 | 11:47 AM
Rexhicks's Avatar
RCM appears to be the no crank issue! But I did check it, and resolder it anyway.
Thanks. Rex
wkdgood
May 7, 2019 01:26 PM
Steenport567
Sep 25, 2011 07:31 PM
MAXIMUSQUO
Jun 17, 2009 12:31 AM
laloggia
Racing
22
Oct 24, 2007 09:20 PM
MMZ_TimeLord
Aug 27, 2007 06:50 PM
