Dash lights and shifting
Old Jul 14, 2018 | 01:53 PM
Salo's Avatar
Default Dash lights and shifting
Bought the coupe, runs good , however when starting up all the light in the dash turn on, and when I put it in gear, it shifts very hard , when I go it appears to not shift by itself, I took it to a mechanic run diagnostics, and it resets, I turn off switch numerous of times, and it's back to normal.. does anyone know what causes that? ? Spoiler goes up and down as well?? If someone could give me an idea that would be great. . BTW mechanic, couldn't tell me cause he would have to have it there for a dew days .. Salomon
Old Jul 16, 2018 | 01:02 PM
Default Re: Dash lights and shifting
replace the RCM better than that remove it send it to tighed1 with 30 dollars and when u get it back it will be better than a new one because with a new one it will go bad within 2 years anyway
Old Jul 16, 2018 | 02:30 PM
Failure of a new one would not do the Mercedes brand reputation much good. They should have learnt by now what the solution was, I have not had a failure on my RCMs and I have had a Crossfire for close to twelve years now, not many miles though.
I would not hesitate to use a brand new one. The only thing that would deter me is the price, the cheapest are about $130 each as I recall. I carry a spare, in fact what was my spare is now in the car as I decided to see if it worked OK.
Old Jul 16, 2018 | 02:36 PM
For a start the battery causes the spoiler to act up if it is failing or a bad connection comes from the battery.
When you start the car all the dash lights come on, this is a test to see they work correctly, they should then all go off. If one or more stay on that shows you of a fault in their system. Maybe that is not what you meant but your description needs clarification, like what resets?
XFGirl
Oct 21, 2024 07:16 AM
AlexParra
Nov 4, 2015 08:53 AM
offshoreMM
Jan 2, 2011 12:58 PM
holgo123
Feb 7, 2009 05:57 PM
scooterme
Oct 16, 2003 02:14 AM
