If it does start...
Old Sep 16, 2018 | 09:56 PM
Bad Habit's Avatar
Default If it does start...
If it does start, it will idle for a few minutes, then slowly reduce idle and die. Then if I try to start again, it will just crank and crank like it is fuel starved. I replaced the crankshaft position sensor a few weeks ago. I thought I had it fixed. And yes, I used a Bosch sensor. When it starts and I drive down the road and back, It will still slowly reduce idle till it dies. Can anyone point me to a good starting point?? Thanks in advance..... oops, it is a '04 n/a
Old Sep 16, 2018 | 11:01 PM
Default Re: If it does start.......
I think I would start with a fuel pressure gauge on the system. See what the pressure readings are as the issue arises. Process of elimination.
James
mmcandre
May 8, 2018 09:39 PM
ecenterprise
Jul 30, 2016 11:07 PM
gregcormier
Jun 28, 2013 12:09 AM
m alexandro lopez
Jun 3, 2008 05:48 AM
Extensive
Oct 12, 2007 03:55 PM
