Rubbery clutch to no clutch
Old Oct 1, 2018 | 10:34 PM
jdorn001's Avatar
Default Rubbery clutch to no clutch
2004 crossfire suddenly stopped shifting. It felt like I was stretching a large rubber band. When the motor was running, it would not go into gear, but the car would move if I kept pressure on the shifter. When the car was off, it shifted easily.
I found a similar another post, and bled the slave cylinder until it ran clear (4-5 cycles...) - between bleeds, we had to pump the clutch a few times to get pressure. I also did the brakes for good measure, and refilled the reservoir. Let it sit overnight, and the reservoir was down a bit so put in another 1/4 can of DOT4. No change, so bled the slave 1x to ensure no air, and now the clutch peddle moves freely with no resistance.
No fluid or other gunk on the master, and video showed the slave dry as well (dirty, but dry). I'm thinking the master is shot. We already have the lower dash out.
Looking for tips on changing out the master (if that is the issue), or any other ideas or suggestions,
Old Oct 27, 2018 | 05:00 PM
jdorn001's Avatar
Default Re: Rubbery clutch to no clutch
Update : changed out the master cylinder, let everything sit while I was out of town, and bled the system while under pressure
I can see the slave moving and pressing on the diaphragm, but the car still will not shift into gear once it is running ... any idea would be appreciated
Old Oct 28, 2018 | 05:05 PM
jdorn001's Avatar
Further update .... some of the 'fingers' on the diaphragm spring are bent inwards, so this would not allow the entire friction pad to be moved away from the engine (i.e. the transmission is always receiving power). Guess it is time for a full on clutch replacement since things have to come apart!
Old Oct 28, 2018 | 09:33 PM
Speedy4x4's Avatar
ya, when the fingers on the pressure plate are worn would be time for a new clutch and pressure plate.
how many miles do you have on it?
I have seen some here have to replace between 50k -240k miles depending on driving habbits.
Old Oct 29, 2018 | 02:51 PM
jdorn001's Avatar
It is a 2004, with 107k miles. We picked it up a year ago for our son. Checked & replaced all the basics - brakes, shocks, coolant, sludge that was oil at one time
He learned on my RX8, so its not a matter of skill - just probably clutch age and hard use from an eager 17yr old. He says the Crossfire shifting is easier
Old Nov 3, 2018 | 12:47 PM
Speedy4x4's Avatar
Did ya change everything?
glad it working better.
I have 172,200 miles on mine atm.
sorry for the late response, been hectic for me past 3 weeks
Old Nov 13, 2018 | 12:14 AM
jdorn001's Avatar
Hectic here too ... son doesn't have the $$ for a new clutch kit, so he was looking into picking one up from a junk yard as a temp until he could save enough. maybe the black friday sales will find one in his price range
Until then, the drive shaft is disconnected, bolts are out, only thing holding it in place is the jack and mount/bracket.....
Old Dec 24, 2018 | 03:29 PM
jdorn001's Avatar
New clutch is in, fixed the problem!
Now to keep the car running - it starts occasionally. When it does start, we can get it to run for maybe 5 minutes before it quits, and won't restart for a while. It's been sitting for maybe 3 months without running - not sure if that makes a difference
DavesX-fire
Jan 20, 2005 05:48 PM
golfdude
Oct 18, 2004 12:27 PM
MiamiCrossFire
Oct 8, 2004 11:32 AM
Dank
Jul 18, 2004 10:53 PM
likquidxero
Apr 22, 2004 01:45 AM
