***RCM issues ?? HELP !
Old Oct 11, 2018 | 05:52 PM
Space coupe's Avatar
Default ***RCM issues ?? HELP !
So I’ve already started another thread but I’m makin another as my issues grow worse and I’m in seek of potential immediate solutions. I’ll quote this with the original thread post that’ll describe my initial issues.
So on top of the Christmas lights on my dash that being the brake wear indicator, BAS ESP (traction control), hand brake light, ABS are all on And my spoiler is stuck sticking out I have no control over it.
now to add to that my alternator is on the fritz.. one day it works and the next day it doesn’t.. took it to auto zone twice one time they claim the voltage regulator within the alternator was bad took it to a different one a day when it was working and they said it passed perfectly fine and the same thing happened after taking it to a local shop.
I took it the shop initially to have a continuity test to make sure it was no significant voltage drop between any of the charging system components and inside the car. they also gave me an extensive list of electrical issues with my car.. some I agree with others not so much. If anyone is interested and seeing the codes and possibly helping me unwrap this mystery
they claim they can fix this issue with a price starting at $500 and wouldn’t exceed $1200. I can purchase some of the pieces which I think would be needed to fix some these issues but I’m not sure if they’re causing the issue.. such as the speed sensors for all 4 wheels (have the manual trans) and new abs/cab sensors for it all and possibly a rcm for roughly $300-$350 for it all
Old Oct 11, 2018 | 05:54 PM
Default Re: ***RCM issues ?? HELP !
https://www.crossfireforum.org/forum...light-all.html
Old Oct 11, 2018 | 05:56 PM
does this appear to need a soldering job ? The 3 traction control relay pins at the top left hand corner
Old Oct 11, 2018 | 07:43 PM
Not to my eye, but you really need to look at it with a powerful magnifying glass.
Old Oct 11, 2018 | 09:38 PM
KDW4Him's Avatar
The right pin of the right connection looks like it's starting to show signs. It's out just do it!
Old Oct 12, 2018 | 11:03 AM
tighed1's Avatar
Symptoms point to a bad traction control relay. Manually close the relay, then start the car. If symptoms go away BINGO!
Contact me for repair if it is the relay.
tighed1@hotmail.com
Old Oct 14, 2018 | 12:13 AM
Which relay exactly is the traction control relay because the inner 3 relays all close fine when the car is started up ?
Old Oct 14, 2018 | 09:00 AM
sirharper
27
Oct 1, 2016 11:08 AM
bodhijames
Jun 10, 2016 06:55 PM
eragonmp3
17
Mar 15, 2016 05:02 PM
jtaylortech3
18
Nov 27, 2015 09:00 AM
codybrown
Jan 16, 2014 01:50 AM
