question about mixing synthetics w/mt??
Old Nov 3, 2018 | 02:04 PM
dohcfiend's Avatar
Default question about mixing synthetics w/mt??
I think I read this trans calls for 70/80 from mb but was curious about mixing to get the best of both worlds. for example gm synchromesh is considerably lighter so if I went 1.7L factory to 0.3L synchromesh............I am assuming once it heats up they would mix bringing it to like a 63/75 or something but when it sits and is cold would the lighter oil separate and go to the top?
i.e. when cold it would be utilizing the lighter oil since it is on top then mix with the heavier oil when warm??
thanks in advance
Old Nov 3, 2018 | 03:15 PM
waldig's Avatar
Default Re: question about mixing synthetics w/mt??
ITS OIL, the syn is more stable, no magic chemistry, use and enjoy. Woody
Old Nov 3, 2018 | 05:21 PM
thanks in advance
The manual states MB approved 5W-30 oil for the manual transmission. The viscisities you mention are for differentials. Using those oils in the gearbox would be really wrong.
Old Nov 3, 2018 | 08:12 PM
I ran Mobile 1 5W20 in my Graphite (on recommendation of John Moorehead and John Tlika, who both tried it) and I found I got smoother shifts.
Old Nov 5, 2018 | 07:45 PM
harbor's Avatar
Crossfire manual trannys had a factory fill of ATF fluid while the identical tranny in the MB SLK 320 came with 75W80 manual trans fluid.
The DaimlerChrysler owner’s manual allowed 5W20 motor oil as a substitute (although syn wasn’t specified), while MB lists no alternative to their factory fill.
75W80 or 90 trans fluid has a similar viscosity to 5W20 or 30 motor oil - See forum member Kamilspider's Kinematic viscosity chart in the below link.
The Franken-brew mixture you are considering would probably be OK, but there may be some other additive issues/clash with the mix. I think you’d be better off using one fluid. See the below thread with the imbedded links, and see if that helps your decision making.
https://www.crossfireforum.org/forum...-question.html
jetdriverk
Nov 21, 2012 02:18 PM
satellite
Sep 28, 2010 01:52 PM
shubi.s
Jun 9, 2009 12:08 PM
BRappaport
Sep 1, 2008 06:38 AM
