Keeping brake dust off the rim?
Old May 20, 2005 | 05:28 PM
slick313's Avatar
Question Keeping brake dust off the rim?
Does anyone know how to keep any amount of the brake dust from collecting on the rims of the crossfire's wheels? I seem to be cleaning my rims almost every day it seems. It seems that the brake dust is collecting at a much faster rate then when my crossfire was new. Also, does anyone know the best way to clean the crossfire's wheels?
Steve
Old May 20, 2005 | 05:47 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Keeping brake dust off the rim?
Steve
your best bet is to change the brake pads to a dust-free compound. i have "rotex gold" pads on my crossfire...this cuts the brake dust by 90%. the pads are less than $100.
http://www.brakeworld.com/
the other choice is to use: "wheel wax" a product made for just rims & aids in brake dust build-up.
http://www.wheelwax.com/
Old May 20, 2005 | 06:39 PM
mustangdriver's Avatar
rotex gold pads is the way to go. Call brakeworld and speak to John.
Old May 20, 2005 | 08:24 PM
Aero Blue's Avatar
Question Re: Keeping brake dust off the rim?
It seems that these Rotex gold's are the way to go, are they carbon/ceramic? It seems that German cars have very aggressive pads, guess it just goes with the territory. While I've got your ears though, if one were to drive pretty normal, how long should these stock pads last?
Old May 20, 2005 | 11:35 PM
andrew's Avatar
the rotex pads are made of a "ceramic" compound.
your stock front pads should last about 30k or so (depending upon your driving habits).
aftermarket pads will last longer...b/c they are made of a harder compound...hence less dust.
this is the best $70 or so you could spend on your crossfire.
cheers!
ROTEX BRAKE PAD INSTALLATION INSTRUCTIONS: (diy)
Tools Required:
flathead screw driver
needle nose pliers
3/8 ratchet w/ extension
7 mm allen wrench
7 mm allen socket
17 mm socket w/ extension (for easy of removing lug bolts)
floor jack
torque wrench
Steps to follow:
1.) Use a floor jack and tools to loose lug nuts. (suggestion: use electrical tape around exterior lug wrench bore for added protection from scratches to your rims)
2.) Use a floor jack to lift vehicle so the tire is 2" off the ground.
3.) Remove loosened lug nuts with 17 mm socket and extension. (use electrical tape on this socket as well)
3.) Use flat screw driver to push piston clip to compress position. Place screw driver in the back side of caliper between rotor and inboard pad. Twist screw driver against pad and rotor to move piston.
4.) Remove front caliper clip with screw driver or pliers.
5.) Remove sensors gently by pulling on sensor to unplug.
6.) Remove black plastic caps on backside of caliper.
7.) Use 7 mm allen socket and/or 7 mm allen wrench to remove both long allen bolts.
8.) Remove caliper from rotor (do not allow caliper to hang by brake lines). Set caliper on top of rotor, securely.
9.) Remove factory brake pads. Install inbound "Rotex" pad into caliper (no clip is used for piston). Install outboard pad onto rotor bracket housing.
10.) Side caliper over rotor. Secure caliper by inserting caliper allen bolts into the rear of caliper. Make sure bolts are in place correctly. Then tighten 7 mm allen bolts firmly. (*Note: Caliper will seem semi-loose, but this is normal).
11.) Reinstall sensor wire.
12.) Reinstall plastic caps on backside of caliper.
13.) Reinstall front caliper clip.
14.) Reinstall wheel and tire. Hand tighten lug nuts with 17mm socket. The tighten securely with lug wrench. Lower vehicle with floor jack and retighten lug nuts when vehicle is on the pavement. Torque lugs to 81 ft lbs.
15.) Start car and apply brake pedal repeatedly until pressure has built up. Drive as normal.
Old May 20, 2005 | 11:55 PM
Dan Root's Avatar
Banned
Or just pay a brake guy $20. That's what I did. Best mod for under a $100, is the Rotex Gold is a kevlar compound "I was told "...is this the same as ceramic?
Old May 26, 2005 | 10:33 AM
dadof4's Avatar
I installed the Rotex Gold's (Front) just over a month ago. It took about an hour for me to install. The pads are great. I spent way too long last year cleaning brake dust off the front wheels. So far, it appears the fronts now stay about as clean as the rears. I have experienced no brake noise with the pads. This mod is well worth the few bucks.
Old May 26, 2005 | 11:34 AM
MARK_UK's Avatar
If only I could buy them in the UK :-(
Just brought some Turtle Wax Extreme Brake Dust Barrier spray. Giving it a go in the morning.
Old Jun 28, 2005 | 07:57 PM
MAYAman's Avatar
How did you get these for $70? I am buying them now and my shopping cart says $85.
Old Nov 19, 2007 | 11:53 AM
huudoo's Avatar
i wash my car 1 time a week clean / wash and spray the wheel 2 times a week.
i found a, fine hair brush... i.e car brush if you will call it that,
at Target and Walmart they work great for me i do not have to rub them
by hand just the Brush and soap. the 1 at Target has a hose connector for
$5.99, the 1 at Walmart was $2.84 no hose connector. both work great!
oldbiff
Mar 19, 2023 11:37 AM
Jonacross
20
Jul 17, 2017 11:19 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
caseydeankopp
Sep 13, 2015 07:25 PM
jaesa
Sep 7, 2015 01:50 PM
