p0600
Old Mar 28, 2019 | 01:49 PM
rule76's Avatar
Default p0600
Good afternoon request help I have a problem with Crossfire 2006, the problem is with dashboard = (cluster) does not work the needles get crazy when I turn on the car and when I turn off and remove the key The dashboard witnesses are lit all the Time I have fault code p0600 I hope your help.
Old Mar 28, 2019 | 02:15 PM
maggy55's Avatar
Default Re: p0600
This is what I'm seeing :
Possible causes Faulty Engine control Module (ECM)Engine control Module(ECM) harness is open or shortedEngine control Module (ECM) cicuit poor electricl connectionLow battery voltage
Old Mar 28, 2019 | 02:16 PM
maggy55's Avatar
Default Re: p0600
Trouble Code P0600 indicates your Mercedes S500 has experienced a Serial Communication Link Malfunction. This means the ECU (one of which is located behind the passenger side floor mat toward the firewall) has lost communication with one other or more module(s), possibly through a short, disconnected wire or harness, or pushed-back pin. The fault more than likely lies in your S500's wiring.
We recommend first doing a battery reset. Check to see if this re-establishes data communication between the ECU and module(s). Your Mercedes S500 is equipped with several control modules such as the instrument cluster module, transmission module, climate control module, SRS module... Should any of these modules fail to communicate with one another a OBDII Trouble Code P0600 will be set.
If a battery reset (disconnect battery terminals for 10 seconds and reconnect) does not solve the problem have a Mercedes specialist diagnose your vehicle's P0600 problem using an SDS (Mercedes Benz Manufacture Specific Scan Tool). The SDS will narrow down the module which has the communication fault. NOTE: Perform battery reset with caution and at your own risk. Be aware all memory, radio codes, and Emission Monitors might erase.
Old Mar 28, 2019 | 02:27 PM
Default Re: p0600
He said he had a 2006 Crossfire not a Mercedes S500? I realize the code meaning would probably be the same.
Old Mar 28, 2019 | 03:18 PM
maggy55's Avatar
Default Re: p0600
Just trying to give him some ideas
Old Mar 28, 2019 | 04:18 PM
Default Re: p0600
That post was a cut and paste from a thread by Smogtips .com with no source acknowledgement given.
Old Feb 13, 2022 | 03:46 PM
Bzak1pgh's Avatar
Default Re: p0600
Ok. I bought a Bosh Crankshaft Sensor and replaced it, car ran great the first day.... the second day on the other hand, did the exact same problem as above Check Engine light and the BAS light back on and won't shift gears with 2 P0600 Codes stating "Serial Communication Link". Nothing else.. any suggestions???
DadsXF
Jan 5, 2020 06:39 PM
onempty
15
Nov 1, 2013 08:19 PM
normw
May 5, 2011 08:18 AM
myrizla
Mar 17, 2011 06:45 PM
Windward
May 11, 2007 10:39 PM
