Accelerator taking a few seconds to react with engine
Old Apr 8, 2019 | 03:08 PM
Dustin_Campbell's Avatar
Default Accelerator taking a few seconds to react with engine
This is my 2004 Automatic coupe, Chrysler Crossfire...
I think it might be my acceleration positioning sensor on my petal but I'm not sure. Everytime I put the petal to the metal, my 2004 Crossfire might be going into limp mode??? I just cleaned my Throttle Body out very very good and this issue is still happening. Basically what's happening is... After I mash down the car to accelerate very quickly, my petal is taking a few seconds to realize the petal is being pushed down. When I give my car a break, it seems like when I start it up again, it's fixed until I put the petal to the metal. It works great until I put it to the floor for more than 5 seconds. I think my sensor might be starting to go out. I don't wanna spend $230 on a new petal if that isn't the problem. Any help and advice on what to do except taking it to the dealership. Any common problems that might be making this happen? I have a stock, automatic coupe, 2004 Chrysler Crossfire. Also there is a rattle when I hit the gas hard when taking off, only in the front. Not the rear. I think it might be the heat sheild around the engine. It's very loud on the out side and inside of the car. It's very annoying and not sure where to start of finding where the metallic, vibration noise is coming from. I could use all the help I can get. This is my first car and want it to last a very long time. It is not new by the way.
Old Apr 8, 2019 | 07:08 PM
Sexy Back's Avatar
Default Re: Accelerator taking a few seconds to react with engine
I have the same issue throttle issue with my 2005 crossfire coupe. Also, the same metal tingy rattle occurs under the front end of my car. I think it’s the heat shields but will know for sure soon. Do you have any other pics of your car? I have the same gray exterior color and I’m thinking of painting the trim same as the body color.
Old Apr 8, 2019 | 08:31 PM
Bill F's Avatar
Try the throttle body reset.
1. Get in your car
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 mins. for a full alignment.
6. Drive the car as you always do.
Old Apr 8, 2019 | 10:10 PM
Sexy Back's Avatar
Bill, mine sometimes revs high between 1st and 2nd gears. My car is an automatic too. Any ideas?
Old Apr 9, 2019 | 01:40 PM
Have you looked for any codes being set?
Did the problem suddenly occur or had you done something just before it occurred.
Old Apr 9, 2019 | 06:14 PM
NeedsWings's Avatar
if the throttle reset does not calibrate correctly, you probably have a bad throttle body or bad gas pedal.
Old Apr 9, 2019 | 09:03 PM
The codes showing were; p0123 and p0410. The last thing I done before I noticed the delay was trying to spin the tires in grass by slamming the gas petal down a couple times.
Old Apr 9, 2019 | 09:09 PM
The reset didn't help. The delay came back after I got done accelerating hard. Every start up, the car resets and it's gone til I hit it hard for more than 2 second of acceleration while in drive. I was thinking it might be a bad sensor on the throttle body so I bought a used one about half the mileage I have on my car now. The code p0123 is being thrown which lead to the throttle body... The reason I ordered a replacement TB.
Old Apr 9, 2019 | 09:14 PM
SAME PROBLEM! I noticed it was reving a little too high for being in park off a cold start. It was doing it by itself, up to around 1.5-2 rpms. It might be the code being throw for the air injection pump. Code is: p0410. It caused my engine light to come on. So I ordered one hoping it will help. But this random reving stopped after 10 sec and this is the first time I've seen this happen.
Old Jun 14, 2019 | 09:18 AM
Mark1's Avatar
I had 0123 on my 2004 roadster but found it was the throttle pedal I changed the whole thing but I think it was just the kick down switch very simple to change just one 10mm nut and two plugs.
Old Nov 25, 2021 | 02:43 AM
SRT-AMGVirginia's Avatar
what was the verdict in the end? I’m having the EXACT same issue. Both codes were thrown at different times.
Old Oct 26, 2022 | 07:28 PM
Nynick8's Avatar
any updates on these issues?
Old Oct 27, 2022 | 10:52 AM
Apparently, not...
Old Feb 4, 2023 | 04:30 PM
Two different issues. The throttle pedal was one. And also my secondary air pump was disconnected from the hose. Must have came up done when I added the DCAI. Hope this helps.
lslajohn
Oct 28, 2022 11:44 AM
colink
Sep 11, 2018 08:55 PM
onehundred80
Other Cars Etc
Jun 15, 2016 09:52 PM
LrdVprScrpn
Mar 18, 2007 09:58 PM
adf3786
Oct 27, 2003 05:53 PM
