Srt6 tbi?
Old May 18, 2019 | 12:39 PM
Show boat's Avatar
Default Srt6 tbi?
Can a throttle body from a supercharged engine be used on a regular Crossfire with a auto transmission?
Old May 18, 2019 | 01:12 PM
Default Re: Srt6 tbi?
Yes, that is normally called a 74 MM upgrade.
The NA ( regular ) crossfire TB is 68 MM.
Old May 18, 2019 | 01:28 PM
Show boat's Avatar
Thanks . Found a 77mm. Wanted to make sure before I buy it
Old May 18, 2019 | 01:43 PM
74 mm, NOT 77 mm !!!!!
Old May 18, 2019 | 01:46 PM
Show boat's Avatar
Its a reworked and modified 74.
Old May 18, 2019 | 01:59 PM
If the bore that it feeds is 74 mm then you are wasting your time, also you should add a 74 mm MAF or you are wasting your time. Air should flow through a constant diameter bore or you get turbulence which is counter productive.
Old May 18, 2019 | 02:01 PM
Show boat's Avatar
Thanks for the info. Ill rethink my ideas.
Old May 18, 2019 | 11:18 PM
Show boat's Avatar
So I found a donor convertible. Besides the TBI and MAF is there anything else that I should get?
Old May 18, 2019 | 11:57 PM
Yes, a tune from Eurocharged .
Old May 19, 2019 | 12:17 AM
Show boat's Avatar
Hows that?
Old May 19, 2019 | 12:22 AM
Show boat's Avatar
thanks. Found one in Fairfield.
Old May 19, 2019 | 02:00 AM
Hows that?
crossfire-performance-engine-software-with-euro-flash
Old May 19, 2019 | 08:10 AM
zip439's Avatar
The search engine on this forum is a wonderful tool; Like most tools, if and when used properly, prevents a lot of verbal chatter.
Old May 19, 2019 | 10:02 PM
Don't forget to use your original sensor in the housing (the MAF housing). Also, trim out the baffles and screen in the curved intake below the MAF and above the TB. Good luck!
Old May 19, 2019 | 11:51 PM
Keep your old TB close by, most of the ones that were modified make the car run radical,,
Old May 20, 2019 | 07:54 AM
I think that is not quite true, mine and many others ran as if there was no mods done, a few had to do a few runs before irate settled in and one or two had to do a few hundred miles before it settled down. Odd but that was what l recall.
Old May 20, 2019 | 09:37 AM
How was yours modified ?
I just installed an unmodified 74 mm and had no issues at all.
Old May 20, 2019 | 10:13 AM
I used a 74 mm TB, a 74 mm MAF using the old sensor, the larger two piece engine cover with K&N filters and the larger intake tubes that fitted the engine cover.
I did not remove baffles or screens, why bother as any increase in power would be unnoticeable. HP at the rear wheels would about 190 to 195 at best.
A year later I got the SRT. I
Old May 20, 2019 | 10:20 AM
Show boat's Avatar
Would you happen to know the OEM number for the SRT throttle body? I've seen too many on Ebay. Thanks for the info
Old May 20, 2019 | 11:13 AM
It is noted in these PDFs. CLICK
and this one. CLICK
