Load resistors for front blinkers?
Old May 22, 2019 | 10:19 AM
Ajbarbier's Avatar
Default Load resistors for front blinkers?
Hello, I have LED turn signals both front and back. I’m beyond sick of the hyper flash, but my confusion about the load resistors comes from the front. How the heck do you wire these things up if it’s only a socket with no wire connection? Any help would be greatly appreciated. (Ps I tried searching but could not find anything)
Old May 22, 2019 | 07:09 PM
Default Re: Load resistors for front blinkers?
You would connect the proper sized resistor from pin 1 of each headlight connector to ground.
I do not know what the proper value for the resistors is.
Even though pin one is not labeled in the above diagram, it IS the input for the turn signal bulb.
devilduck
Mar 8, 2012 12:48 AM
James1549
Jan 12, 2011 08:57 PM
Thirteendog
Oct 6, 2010 06:28 AM
Raz83
Sep 21, 2009 06:24 AM
nox1s
Jul 7, 2008 04:04 PM
