Magnesium Valve Cover Corrosion
Old May 24, 2019 | 08:36 PM
Default Magnesium Valve Cover Corrosion
I'm seeing the initial signs of surface corrosion on the aluminum/magnesium valve covers of my 2007 Coupe. The PS valve cover has some significant corrosion on the front end which is quite visible to the naked eye. Looks like I'll be spending some time this weekend cleaning up this surface corrosion and inspecting both valve covers thoroughly to see if there are other spots with signs of surface corrosion. I need to look over the intake manifold also.
Old May 25, 2019 | 08:28 AM
UrbanE's Avatar
Default Re: Magnesium Valve Cover Corrosion
Remove them and paint them with engine paint.
Its fast, easy and they will ook great.
Or or you can spend the next week trying to polish them.
Old May 25, 2019 | 08:35 AM
new black crinkle valve covers
Old May 25, 2019 | 09:49 AM
I'm seeing the initial signs of surface corrosion on the magnesium valve covers of my 2007 Coupe. The PS valve cover has some significant corrosion on the front end which is quite visible to the naked eye. Looks like I'll be spending some time this weekend cleaning up this surface corrosion and inspecting both valve covers thoroughly to see if there are other spots with signs of surface corrosion. I need to look over the intake manifold also.
As a side note, are they magnesium? I thought they were an aluminum/magnesium alloy, magnesium is expensive, aluminum is not.
Old May 27, 2019 | 07:38 PM
You are correct again, onehundred80. Sorry for the confusion. Valve covers & intake manifold are an aluminum/magnesium alloy.
Old May 28, 2019 | 09:44 AM
I have whitish spotty light corrosion on the intake plenums and I would like to take it of. It is just spots and I would not want to make it more obvious than it is, any ideas? I might paint the spare valve covers at some point, black or silver, until I make up my mind what colour I’ll put that on the back burner.
Thanks.
Old May 28, 2019 | 01:10 PM
Thanks.
I've ordered the product in the attached receipt after viewing a couple of videos on it. I'm going to give it a try as I have that same whitish spotty corrosion on the PS valve cover visible from the front of the motor. Not really interested in removing these parts right now and performing a more permanent fix.
Here are links to the YouTube videos I found:
Hope this helps,
dylan07
Aug 20, 2017 09:19 PM
GDrag
Jan 19, 2012 08:39 PM
NeedsWings
Jun 8, 2010 10:44 AM
Maxwell
May 24, 2007 05:35 PM
Jl2row
Mar 31, 2007 08:09 PM
