Removing 48 pin plug cover?
Old Jun 23, 2019 | 07:55 AM
TR6P's Avatar
Default Removing 48 pin plug cover?
Can anyone give me an idiots guide to removeng the cover over the 48 pin plug without forcing it please?
Old Jun 23, 2019 | 09:15 AM
Default Re: Removing 48 pin plug cover?
I have taken mine off before, the socket is held on by a lever which is part of the assembly. Opening the lever loosens the socket, I am afraid that is all I remember. Maybe the method is in the Service Manual.
Forcing it will wreck everything.
Old Jul 2, 2019 | 11:40 PM
Space coupe's Avatar
It’s 2 small tabs on either side of the connector lever, lift at least on side off the locking tabs then pull up on the lever and it’ll disconnect itself. Re connecting is in the reverse order, make sure to leave the lever up when first connecting it other wise it won’t actually connect properly and throw codes.
Old Jul 4, 2019 | 07:42 AM
zip439's Avatar
See if this makes sense to you: lift up on top part while twisting a screw driver blade between the edges to force connector open. The outer cover can be removed first by pulling it at the top.The cover snaps into the "handle" of the connector which you will pull up once the cover is off.
samo59
Jan 20, 2013 11:43 PM
ProjectMayhem
Oct 22, 2009 10:11 PM
RJ44130
Nov 19, 2008 06:29 PM
jpristel
Jun 29, 2008 01:05 PM
tylerxfire
Apr 22, 2008 05:05 PM
