Engine hoses
Old Jul 20, 2019 | 12:00 PM
Xfirewhiteghost's Avatar
Default Engine hoses
Can someone please tell me where I find the pre-molded engine breather hoses for 2004 crossfire w/ 3.2 engine? I also need a window motor regulator for driver side and new front turn signal housing components. Its disturbing I can't locate some of this basic stuff.
Old Jul 20, 2019 | 12:05 PM
Default Re: Engine hoses
Probably only on Ebay unless there is a Mercedes part that is the same.
Old Jul 20, 2019 | 12:09 PM
zip439's Avatar
Your car is basically a Mercedes 2003 SLK 320. Use any online Mercedes part dealer, Or FCPEuro.
RedLine Auto parts online has parts specific to Crossfire. You can probably find all the window stuff there. It will have come off a salvaged Crossfire.
The turn signal can probably be repaired. Use the search box upper right corner of forum and search for turn signal.
Old Jul 20, 2019 | 12:12 PM
NeedsWings's Avatar
NeedsWings Performance Products. Part Load Crankcase Ventilation Hose Assembly m112
Old Jul 20, 2019 | 12:37 PM
Originally Posted by Xfirewhiteghost
front turn signal housing components. (
That is part of the headlight assembly, they are easily available and cost over $400 each, even used ones.
What exactly is wrong with it? I find it odd you are not asking for the headlight assembly but instead the "turn signal housing".
What are you really looking for?
killerkanadian
Sep 18, 2011 09:52 PM
Sarina
Aug 28, 2011 06:42 PM
94 White RT
Aug 2, 2010 09:14 PM
TROKHER
Jul 27, 2010 01:29 PM
Cincinnati Slim
Apr 15, 2007 06:31 PM
