Front glass roof bar gasket
Hi, I am new here, and I am from Poland and I have few questions about my car. First one below.
Does anybody know how to remove this plastic bar which is above the front glass? The gasket which is glued to it started moving in my car and making a lot of noise during the ride (it vibrates and hits the glass). I want to do this properly but can't find any instructions or I don't know how tu call this part in proper way in english.
Second one. Can I use extra two bolts to screw the rear registration plate, because it is shaking and making noise too? Is there enough place between the bumper and plate? In Poland we have longer plates...
Thanks in advance.
Thanks in advance.
I had the same issue on the front molding. The top trim will pull off. Purchase some thin double face tape the appropriate width. Reapply the rubber gasket and then install the molding back on the car.
I used four screws on my US plate with no problem.
Thanks in advance.
Thanks in advance.
Thanks for replay, but do You have any pictures how does it look like after removing? I don't want to break it. In which direction to pull of? Up, front, back?
I have just found the pictures, but i shoud pull up or use some tool?
Youngautomechanic
Feb 26, 2020 04:49 PM
ardenian
Jul 21, 2018 12:53 PM
HDDP
Jan 9, 2009 10:29 AM
