Burnt out lamp indicator
Old Jun 16, 2005 | 12:52 AM
James's Avatar
Default Burnt out lamp indicator
I installed HID lights into my xfire, everything works perfectly.
However, with HIDs installed, the 'burnt out light' warning indicator comes on in the dashboard, whenever I turn on the lights. I absolutely have no burnt out lights or bulbs on my car --- I think that HIDs may pose a different resistance draw on the 'burnt out light' sensor/circuit and 'fools' it into coming on.
Has anyone else had this problem?
Old Jun 16, 2005 | 08:21 AM
aschrager's Avatar
Default Re: Burnt out lamp indicator
I have HID's and no such problem. Check all of your connections.
Old Jun 16, 2005 | 08:29 AM
andrew's Avatar
-C-I-C-C-I Associate Member
same here...no problems with my hid's.
Old Jun 16, 2005 | 11:17 AM
James's Avatar
Thanks for getting back to me...
Very interesting. I have checked all of my HID connections. If I put the factory headlight bulbs back in, No problems. Unplug, and plug in HID harness, and the 'burnt out bulb' indicator comes on. (This whole problem only exists when I have the headlight switched on, ie: at night. When lights are off, obviously no problems). I have tried 2 replacement harness/ballasts with the same results, so I know it's not the HID kits themselves. Maybe my car's circuit is just more sensitive to the resistance change... btw, I used the XenonDepot HID kit. I know of one other person who has the same problem as me with their Xfire.
Old Jun 16, 2005 | 01:29 PM
Simon Templar's Avatar
Put a multi-meter across both and compare the resistances. If there is a significant difference, splice in a resistor of that value inline with the HIDs.
eikon
Sep 9, 2019 10:16 PM
Mike OD
Sep 23, 2016 07:00 AM
crossfireE
Oct 2, 2015 01:40 AM
tritongreen
Sep 18, 2015 07:32 AM
maxcichon
Sep 4, 2015 12:50 PM
