Indicator relay
Old Jan 21, 2020 | 06:31 PM
Petersrt6's Avatar
Default Indicator relay
Hi
can anyone tell me where the indicator relay is located?
thanks
Peter
Old Jan 21, 2020 | 06:45 PM
Default Re: Indicator relay
I'm not sure if it's a language problem or not, but could you please describe what the indicator relay does ?
Old Jan 21, 2020 | 06:53 PM
Petersrt6's Avatar
Indicators are used to indicate turning or changing lanes. In most of the planet this is done via a seperate bulb/ light. In the U.S. you have a combined brake/ indicator bulb ( bad idea I think).
we see imported fords here and they come with the compromise indicator - parker bulb which flashes when used as a indicator. Poor mans idea me thinks.
Old Jan 21, 2020 | 11:39 PM
Originally Posted by Petersrt6
Hi
thanks
Peter
It is in the under hood fuse box.
Old Jan 21, 2020 | 11:44 PM
Petersrt6's Avatar
Any location within the fusebox, I tried looking in the fusebox already with indicator swiched on, couldn't detect any noise.? I know one of the two small relays inside fusebox on top is for windscreen washer pump.
Peter
Old Jan 22, 2020 | 09:09 AM
KeithTexas's Avatar
Peter
Take a look at this thread. It may not be easy getting to the relay....I'd suggest trying everything else you can first. Does the hazard switch turn all flashers on?
Turn signal relay
Old Jan 22, 2020 | 03:19 PM
Petersrt6's Avatar
My reason for answering is having installed LED bulbs throughout the vehicle, the turn (Indicator) relay see's the high resistance of the LED and flashes faster.
on other vehicles this is easy fixed by replacing the flasher can with a LED compliant relay.
its no real big issue, as the flasher works fine, just a quicker flash.
Peter
BobG
Nov 21, 2019 09:52 AM
CrossfireRSSS
Dec 4, 2018 10:34 PM
mexico63
Apr 20, 2013 10:54 AM
Louie K
Aug 11, 2007 08:25 AM
Napasanaoma
May 25, 2006 09:39 PM
