Possible Water Pump Replacement
Old Feb 13, 2020 | 02:34 PM
levalkyr's Avatar
Default Possible Water Pump Replacement
Long-time lurker of these forums. I have had an issue with my xf recently. It all started with a grindy sound coming from the engine. After inspection, there weren't any issues directly looking at the engine, so I continued. A few months later, the serpentine belt shreds on the interstate, so I replace it on the spot. That was 3 weeks ago. The water pump pulley now has a very distinct wobble to it and the previous grinding sound seems to be coming from this area (the water pump?). I just got back from a 45 mile trip and the engine light comes on. After examining the engine, there is quite a bit of coolant splashed around under the hood, mostly under the reservoir and near the water pump. Putting the pieces together, it seems the problem is 110% the water pump or pulley bearings. What are your thoughts on what I have presented? Should I go ahead and replace the whole water pump, or bank on it being a bearing and just replace that? I am quite new to self-service, so any help is appreciated. I can provide a recording of what it looks/sounds like as well if that would help.
Old Feb 13, 2020 | 03:45 PM
Default Re: Possible Water Pump Replacement
Recording not necessary, replace the pump NOW.
You should have done so when you first saw the wobble.
Old Feb 13, 2020 | 08:50 PM
UrbanE's Avatar
Don’t mess with any bearings. It’s just not worth it
water pumps are cheap and it’s an easy change up. A seized engine due to excessive heat is going to chew up a whole lot more money and time.
Old Feb 13, 2020 | 09:41 PM
Water pump, probability @ 99.999%. When you replace, be CERTAIN to follow the hints from those who have done the replacement in the past. TRACK EVERY BOLT using a template, as you remove put bolt in template continuing on until pump is out. Then, put new pump in following the correct bolt in correct hole. The bolts are of differing lengths, so take the advice of those past, and be careful. I am sure you know this but just in case.
Old Feb 13, 2020 | 10:14 PM
levalkyr's Avatar
Yessir! I have read up through these forums about past water pump changes and the key points of changing them. Just double checking with the gurus here before I go digging under the hood thanks fellas and drive safe!
Old Feb 14, 2020 | 03:09 AM
Cotyt94's Avatar
I replaced my pump before. Do not overtighten the bolts! They snap EASILY
Old Feb 14, 2020 | 09:43 AM
They should not snap if you torque them correctly.
Old Feb 14, 2020 | 10:14 AM
Cotyt94's Avatar
yeah thats true but if your not familiar with the torque units they snap easily
Old Feb 14, 2020 | 01:02 PM
Speedy4x4's Avatar
I changed mine in the parking lot of a hotel.
1 week after I had a local shop do a complete inspection.
water pumps are easy.
Most water pumps for our engine do bit have the hole tapped for the idler pulley (nothing that is it, but they are drilled for correct size and the bolt taken out is a thread cutting bolt, going easy it will cut threads as it goes and stay thight.
Old Feb 16, 2020 | 01:13 AM
UrbanE's Avatar
If you’re going to do ANY engine work
BUY A GOOD TOUQUE WRENCH
ft/lbs
and
A smaller one in, inch pounds of the smaller areas
Old Feb 16, 2020 | 01:21 AM
Cotyt94's Avatar
i just remembered something from my water pump replacement expérience. I bought a replacement pump from rockauto.... The GASKET it came with was GARBAGE. if you go that route buy a gasket from an auto parts store. I had autozone order me one for ten bux.
Old Feb 16, 2020 | 11:28 AM
There are two types of gasket that comes with some pumps, a flat one and one that sits in a groove. I do not know the specifics though,some pump photos show both.
Old Feb 16, 2020 | 11:29 AM
There are two types of gasket that comes with some pumps, a flat one and one that sits in a groove. I do not know the specifics though, some pump photos show both.
Wolverine
31
Feb 1, 2016 05:45 PM
DarkNinjah
Oct 23, 2014 07:22 AM
MX5racer
Dec 1, 2013 11:38 PM
Archaic
Jul 24, 2012 01:29 PM
magredvet
Jul 31, 2008 06:41 AM
