Weird rear noises
Old Feb 21, 2020 | 10:58 AM
Zanzib8's Avatar
Default Weird rear noises
Hi everyone,
just bought a 2005 Crossfire Coupe.
l have a rattling noise coming from the rear around underneath the trunk.
l know the rear suspension have been changed.
it’s like the mechanic forget a tool on it!!
Any suggestion??
Thank you in advance for your help!
Old Feb 21, 2020 | 11:04 AM
Default Re: Weird rear noises
Have someone raise it on a rack and look around.
Old Feb 21, 2020 | 02:20 PM
There has been some concerns about the rear stabilizer bar mounts cracking, check that. You don't need to have it on a rack just take the jack one side at a time, remove the wheel, and check the top rear brackets for cracked welds. Doesn't matter which side you do first unless you think it is making the noise on one side or the other. Do the side you think it might be first. If you find the weld cracked, don't stop there, do the other side and make sure it is OK. Good luck!
Old Feb 22, 2020 | 08:35 PM
Put some black tape on the stricker (latch of the trunk) wrap it 3 to 5 times,,,,
Old Feb 22, 2020 | 08:59 PM
Speedy4x4's Avatar
That reminds me of the 2 stops on my hatch, I cut 2 pieces of adhesive door foam strips and put under both of the stops on mine, and noise gone.
waldig
Jul 18, 2011 05:24 PM
CroSSFiRe 407
Jul 2, 2009 12:03 PM
andrew
Jun 29, 2009 10:15 PM
xfirefun
17
Feb 17, 2009 12:02 PM
chxf
Dec 31, 2005 02:00 PM
