Replace Thermostat along with coolant flush?
Old May 28, 2020 | 07:30 PM
Enmanuel09's Avatar
Default Replace Thermostat along with coolant flush?
Hi y'all. My 04 Coupe is at 96k and I will be doing a coolant flush soon since it's been 2 years when I bought it . I was wondering whether I should replace the thermostat as well? So far, car has never overheated or presented any cooling issues. What are your opinions? Thanks.
Old May 28, 2020 | 07:38 PM
Default Re: Replace Thermostat along with coolant flush?
Don't fix it if it ain't broke. Easy enough to change if it does go bad.
Old May 28, 2020 | 07:41 PM
Jim Holian's Avatar
I understand your concern and your interest in preventive maintenance. If it was me, I'd replace everything I could while doing the project. Then, there's the old adage "if it ain't broke, don't fix it". Not sure what to suggest to you. If the car has a lot of mileage, I sure would replace what I could in an effort to stem off any future problems. If low mileage, save some money and go for broke!
Jim
Old May 28, 2020 | 07:48 PM
UrbanE's Avatar
If you’re dumping the coolant anyway and the replacement items are not that expensive
it would be worth it to take a few extra minutes to swap in a new one
Leave the existing one in place and sure as Sh-t it will fail 4 weeks after the flush
if you asked the question, you’ve decided that it’s probably a good idea to do it anyway.
It sure couldn’t hurt.
Old May 28, 2020 | 09:33 PM
I gave advise to leave as is, but in fact I changed mine when I last did a coolant flush.
( do as I say, not as I do )
Old May 28, 2020 | 09:40 PM
16 year old car with almost 100k. Why would you even ask?
Old May 29, 2020 | 11:08 AM
dcskmail's Avatar
You may want to add a product called wetter water to the cooling system it will lower the water temp which is good especially it it's an auto
Old May 29, 2020 | 04:02 PM
Enmanuel09's Avatar
Jim
Thats what I thought. FC Euro has it for about 35$ might as Well.
Old May 29, 2020 | 04:03 PM
Enmanuel09's Avatar
In that case I will be changing it. My dad is also about if it “ain’t broke don’t fix it”
Old May 29, 2020 | 04:04 PM
Enmanuel09's Avatar
summer is already here and I think I will take your advice
Old May 29, 2020 | 04:05 PM
Enmanuel09's Avatar
Do you know if I should add some type of sealant to the thermostat gasket if it comes with one?
James1549
Apr 27, 2015 10:38 AM
arejohn
Oct 22, 2014 02:27 PM
ala_xfire
Mar 27, 2012 06:57 AM
scubaman
Dec 11, 2010 02:17 PM
murtazanooruddin
May 31, 2010 08:51 PM
