Driveshaft Support and Bearing
Old Apr 19, 2021 | 05:01 PM
YAMAHA's Avatar
Default Driveshaft Support and Bearing
Hello, how can I find the part that needs to be changed here. Technical name "Driveshaft support bearing"
I would appreciate it if you write me the chrysler and mercedes part code and the links I can find about it.
And how bad is it that I can continue riding like this? no sound no vibration? Sometimes when I adjust the unstable throttle, I feel a click when the gear is falling. probably this is happening to all of us.
https://streamable.com/ic0hx7
https://streamable.com/l2sa1y
https://exist.ua/mercedes-brand/opor...00-81-3275865/
(is this part correct?)
Old Apr 19, 2021 | 05:48 PM
YAMAHA's Avatar
Default Re: Driveshaft Support and Bearing
30926 FEBI BILSTEIN
can i use this??
Old Apr 19, 2021 | 06:23 PM
Same as a 2003 Mercedes SLK320.
Old Apr 20, 2021 | 10:37 PM
zip439's Avatar
The Mercedes Bearing Number is 008 981 43 25. The rubber support from Mercedes I was not able to find matching number. They seem to want to sell that with the drive shaft. You can get the complete center support replacement at Needswings.com. Not sure what the cost would be for shipping. Also "Partsgeek.com" has the two parts you are looking for search for 2003 SLK drive shaft center bearing. Those are after market parts.
Old Apr 21, 2021 | 04:36 PM
u want the correct part and not worry about what u get as said above in another post
Old Apr 24, 2021 | 05:17 PM
YAMAHA's Avatar
Hello everyone again, today I got the part that needs to be changed. 2 separate services did not say anything clear about how to insert it. the shaft assembly will be disassembled or they do not know exactly whether it is possible to disassemble separately. and that's why they don't tell you the labor cost clearly. I would appreciate it if you write down the procedures and tips for installing this piece. I would like to go to the service, having studied my lesson. Otherwise, there may be a surprise labor price.
jimcross
Jun 19, 2018 08:20 PM
manisusmc
Apr 28, 2010 04:43 PM
waldig
Dec 20, 2008 07:47 PM
