Upper Brake Light 2005 convertible
Old Jul 30, 2021 | 11:05 AM
jeffklitz's Avatar
Post Upper Brake Light 2005 convertible
I have an upper rear brake light that only half lights. Any ideas on where to find a replacement part? I Tried the local Chrysler dealer. They say it is a Mercedes part. Mercedes says it is a Chrysler part. {art Number is A193 820 0856
Old Jul 30, 2021 | 11:12 AM
Ronman's Avatar
Default Re: Upper Brake Light 2005 convertible
It is a Chrysler part specifically for the Crossfire. They are very rare. So you need to gently remove it and pack it perfectly (double box etc) and send it to Cadillac LED Replacement 3rd Brake Light, Third Brakelights For Escalade, ESV, Escalade EXT, Avalanche LTZ, Chrysler Crossfire, 2010-2011 SAAB 9-5, 2015-2019 GMC Yukon, Yukon Denali Tail Light Repair for repair. It is possible you can find a used one on eBay.
Old Jul 30, 2021 | 11:35 AM
jeffklitz's Avatar
Smile Re: Upper Brake Light 2005 convertible
Outstanding. Thanks
Old Jul 30, 2021 | 05:22 PM
Hi Jeff, and Welcome! I see your a new member. You MUST read a few posts here about Chrysler and the Crossfire. They mostly will not be able to support your car and it may sit in the dealership (which we call mostly STEALERSHIPS). Chrysler and Mercedes Benz had a bad divorce, you'll find MB will snub their collective noses and refuse to work on your mostly parted SLK320 (if the N/A 3.2L, not the SRT-6). This forum will help you with repairs with some patience and well prosed posts about what your having a problem with. If beyond your abilities, an independent European mechanic can help with all the SLK320 compatible parts for your XF. If your able to be flexible, some members in your local area might be able to assist you with your car. Otherwise, Chrysler will bleed you dry if you let them. GOOD LUCK!
wmachado
Sep 4, 2019 03:46 PM
Charles Raymond
Aug 25, 2019 10:13 PM
sprite63
Sep 23, 2016 01:07 PM
speedway--Z
Feb 18, 2014 06:50 AM
mophreakous
Oct 19, 2011 11:19 AM
