Windshield washer pump...low output?
Old Jan 20, 2022 | 09:04 AM
JBRDH's Avatar
Default Windshield washer pump...low output?
Any have this issue? Fluid dribbles out of the nozzle... no other apparent leaks noticed... Nozzles appear to be clear of obstruction...
Old Jan 20, 2022 | 09:28 AM
Default Re: Windshield washer pump...low output?
The nozzle opens by unclipping it using the tab on it. This exposes a ball shaped nozzle that comes out, do not drop it. The hose and ball are probably plugged with gunk. Pump some washer fluid through the hose using the end **** on the stick. Clean the hole in the ball and reassemble, align the jet with a pin in the hole in the ball.
Do not use plain water in the washer reservoir as it turns slimy.
dodgemahal
Jan 29, 2018 12:45 PM
dcspride
Apr 1, 2008 05:53 PM
Mediacritic
Apr 17, 2007 11:44 AM
Joevano
Jul 30, 2005 10:44 AM
FLTATT
Jul 5, 2004 10:13 AM
