Cleaning Headlamp Interior
Old Mar 18, 2022 | 08:51 AM
Jack G's Avatar
Default Cleaning Headlamp Interior
One of the tips for cleaning the inside of a headlamp assembly is to use 99.9% lab grade methanol. Has anyone successfully used methanol racing fuel in place of lab grade methanol ?
Old Mar 28, 2022 | 10:16 PM
Jack G's Avatar
Default Re: Cleaning Headlamp Interior
I just tried using lab grade methanol to clean the inside of the headlamps. It did nothing to remove the internal film. I tried the cloth wrapped magnet technique with no improvement. This was tried without and with methanol.
It appears the only solution remaining is to disassemble the lens from the main enclosure. Does anyone have a successful method for doing this?
Old Mar 28, 2022 | 11:13 PM
I would not recommend taking the headlight apart. Are you sure the outside surface is not the problem.
Old Mar 29, 2022 | 05:12 PM
Jack G's Avatar
I have applied the 3M lens cleaning kit a couple of times to make certain the film was on the interior surface. It is definitely on the inside. When I move the cloth covered magnet across the interior surface the film seemed to be unaffected. I tried doing this dry and with the methanol. It looks like I have 2 choices, leave things the way they are or open the enclosure and clean the inside of the lens. Does anyone have experience with separating the lens?
Any help is appreciated.
Thanks
Old Mar 29, 2022 | 07:36 PM
Thanks
Do not put it in the oven as some may tell you.
Opening it up is a poor choice.
Spector01
Apr 8, 2021 08:18 AM
X-Fire_Head
Jul 18, 2011 11:11 AM
cgocifer
May 19, 2008 04:54 PM
willie
Detail Shop
Mar 17, 2004 12:34 PM
