o2 sensor
Old Jun 30, 2022 | 11:05 AM
bc75's Avatar
Default o2 sensor
I have been fighting a lean bank 2 code. I just found on my obd reader sensor 2 bank 1 and 2 are not reading. I moved the bank 2 sensor to bank 1 and it reads. So my question is where does the sensor 2 wire go?
Old Jun 30, 2022 | 11:33 AM
Default Re: o2 sensor
Sensor #2..
Old Jun 30, 2022 | 11:47 AM
bc75's Avatar
Sensor 2 banks 1 and 2. I cant find any reason why it wont read. I move sensor 2 to sensor 1 location it will read.
Old Jun 30, 2022 | 05:59 PM
Maybe you have a good and a bad connection and a good and bad sensor. Put the goods together and that combination works.
Old Jun 30, 2022 | 07:48 PM
bc75's Avatar
I've moved them around today. They read on sensor 1 but not 2. I've followed the wires don't see anything wrong. I was just trying to figure out my lean on bank 2 code. It still hesitates.
Old Jun 30, 2022 | 08:37 PM
Ronman's Avatar
Have you tried cleaning the connectors with electronic contact cleaner spray? Maybe there is some corrosion, you can buy the plugs separately if they need to be replaced, there is a part number stamped on them.
Old Jul 2, 2022 | 08:48 AM
bc75's Avatar
I will try that. Will the bank 2 sensors cause a running lean code?
phil alvirez
Jun 13, 2021 01:36 PM
jamesmonter2
North America
52
Mar 24, 2013 08:56 PM
Ronman
Nov 21, 2012 12:30 AM
nate_man
16
Mar 11, 2012 10:10 PM
lannyx
Feb 12, 2011 05:20 AM
