Manual Sticks In 6th Gear
Old Jul 18, 2022 | 08:41 AM
nedwardwilliams's Avatar
Banned
Default Manual Sticks In 6th Gear
Owned my Crossfire for 16 years with no issues until recently. Sometimes the shifter will get stuck in 6th gear and I have to pull over, turn the vehicle off and push the clutch while working the shifter a few times and after 15-20 minutes it will work free again. There are no early symptoms or warnings. Clutch is not slipping or soft, no grinding or burning smells, no leaks, gear works smooth but whenever it feels like it the shifter will hang in 6th gear. Several independent transmission shops have test driven it and find no issues with the clutch or shifter. Anyone had this issue yet and know what the problem is?
Old Jul 18, 2022 | 09:35 AM
F4celess's Avatar
Default Re: Manual Sticks In 6th Gear
Have you tried plugging in an OBD Reader / Scanner, to see if there are any specific Codes being generated?
Has the transmission fluid been flushed / replaced at all? Read in another Thread where someone had the same issue, locked in 6th, there was debris that dropped out with the fluid when they got round to flushing it.
Plus 16 years ownership must almost be a record.
Old Jul 18, 2022 | 10:33 AM
Banned
Thx for the feedback. Had the transmission serviced 8K miles ago. Replaced fluid with BG premium fluid which comes with a lifetime warranty. Company will repair or replace transmission at no charge up to $4K if the original owner ever has a trans issue. Per your suggestion I will have the linkage checked by the Euro shop that serviced the transmission.
Old Jul 18, 2022 | 11:18 AM
dcskmail's Avatar
Have you flushed and replaced all of your brake fluid ? The clutch and slave also uses the same brake fluid
Old Jul 18, 2022 | 11:39 AM
F4celess's Avatar
Looks stunning in the White !
Interesting, concerning the Antenna on the rear wing. Never really noticed an antenna on the Crossfire's before. Specific to the Convertible it appears (checking on Google pictures of others). So is it hidden under the roof or something on the Coupe!?
Old Jul 18, 2022 | 12:33 PM
Banned
I have the original showroom brochure for all the Crossfire's and it only shows external antennas for the Roadster. Not sure where they are for the coupe and SRT6.
Old Jul 18, 2022 | 06:05 PM
bluecoupe's Avatar
Antenna is in the hatch glass along with the antenna module
Old Jul 19, 2022 | 05:16 AM
F4celess's Avatar
Ok! Thank you for your confirmation. Will take a look.
@nedwardwilliams - Best of luck with the additional checks, relating to your manual gearbox issue.
Old Jul 19, 2022 | 10:35 AM
Ronman's Avatar
There is an amplifier at the bottom of the hatch under the plastic, not an antenna. I think the rear windshield acts as the antenna and gets amplified.
Old Jul 19, 2022 | 10:53 AM
bluecoupe's Avatar
The antenna amplifier is attached to the top of the hatch window frame to the right of the CHMSL.
Old Jul 19, 2022 | 08:41 PM
Banned
Yes, I had the brakes flushed with the same product. I've had the vehicle for 16 years and every 3-5 years I have the entire car gone through and repairs done @ that time.
John8810
Dec 7, 2019 01:51 AM
sg2848775
Nov 11, 2016 10:37 AM
blackcrossfire07
Mar 16, 2010 09:23 AM
ravenous
Apr 27, 2008 06:50 PM
Cincinnati Slim
15
Apr 16, 2008 06:53 AM
