ESP/BAS light staying on after fixing RCU dry joints
Old Aug 17, 2022 | 12:56 AM
GraemeQ's Avatar
Default ESP/BAS light staying on after fixing RCU dry joints
hi
Thought I had solved my intermittent starting issue after reading the good info on here. Found 4 dry solder joints. Put it in and same problem. Checked that all the relays were operating as per advice. Not the ESP/BAS light is staying on. Would help to track down this intermittant start issue?
My issue seems common on here.
regards
Old Aug 17, 2022 | 07:03 AM
F4celess's Avatar
Default Re: ESP/BAS light staying on after fixing RCU dry joints
Have you considered or changed the Crankshaft position sensor, as another "common" starting issue?
Plus might add, you might want to connect a Code reader to the car to see if there are any specific Errors?
Old Aug 17, 2022 | 10:12 AM
BAS/ESP can be caused by bad or dirty wheel sensors.
Old Aug 17, 2022 | 05:25 PM
GraemeQ's Avatar
thanks to those who gave me a hand. I googled the ESP/BAS light staying on and it was because I had disconnected the earth to check the Relay control unit fault.
The fix was to turn the steering wheel to the centre then full left then full right. Light extinguished!!
Man this car has some unusual quirks lol.
Once before when the engine light came on it was suggested to remove and refit the petrol cap and it worked
Old Aug 18, 2022 | 04:41 AM
F4celess's Avatar
So the not starting problem also mentioned in your orginal Post, got magically fixed too?
cg80
Mar 4, 2019 12:08 PM
blackpepper
Apr 27, 2017 10:00 AM
AndyJ
Oct 19, 2014 07:01 PM
skeet370
Sep 13, 2014 01:05 PM
john_Dragon
Oct 7, 2010 04:00 PM
