Ecm
Old Sep 15, 2022 | 06:48 PM
Erics XF's Avatar
Default Ecm
Found a srt6 with 60k miles on for $4,000. The problem is the ecm was ripped out out of anger 😬.
if I bought a eurocharged programed ecm and plugged it in, would it work?
Also would my n/a ecm work?
Old Sep 15, 2022 | 08:59 PM
Default Re: Ecm
No. Neither will work.
The ECU has to be mapped to the SKREEM so one from another car has to be configured for the SKREEM in your car, unless you get the SKREEM and chips for the key fobs from the donor car.
An N/A ECU does not have the code for the supercharger or the tune of the supercharged engine and I suspect it won't talk to the SRT6 TCU, either.
So it's a "NO" for all your questions, but we do have another question: What can EUrochared do for you? Perhaps (I simply do not know) they can remap the ECU for your car.
The ONLY person you should be asking is Eurocharged themselves.
Old Sep 15, 2022 | 09:22 PM
Erics XF's Avatar
Default Re: Ecm
what would I have to do/ how much would it cost to fix this srt6 that won't run due to the ECM/RCM being ripped out?
Old Sep 15, 2022 | 10:23 PM
UrbanE's Avatar
Default Re: Ecm
Watch Ebay
I purchased a spare set in the event mine died and I was unable to get the ECU REPAIRED OR REPLACED
ECU
TCU
SKRERM
BCU
Door lock
Glovebox lock
air bag key switch
2 OEM Fobs
It’s in a box in case I need it.
if you go down the road make sure the donor items comes from the same body style that you have
coupe or roadster
Old Sep 15, 2022 | 10:27 PM
Default Re: Ecm
Again, thats a question for Eurocharged or Josh at the Mercedes Swap Shop. As I said, I don't know how much they can do to program a donor ECU to your car. I do know that if you find a SKREEM, ECU and Keys to an SRT that came from the same car, you can put all three items in your car and be good to go.
Now, the only drawback is that the electronic VIN of the car will change to the VIN of the donor car, so online emissions tests cant be passed by your car, cause the VIN wont match.
But other than that, getting those items from another SRT WILL work.
Old Sep 16, 2022 | 09:46 AM
Default Re: Ecm
I would talk to Josh at MSS (Mercedese Swap Shop).
Old Sep 16, 2022 | 12:26 PM
Erics XF's Avatar
Default Re: Ecm
I decided not to buy it... to much of a gamble. I think I will stick to body work.
Old Sep 16, 2022 | 01:05 PM
Default Re: Ecm
Buy it as a parts car, the guy may come down in price.
Old Sep 16, 2022 | 02:17 PM
Default Re: Ecm
The cost to reprogram the ECU would only be a few hundred dollars. If I were closer, I would jump on it.
Old Sep 16, 2022 | 11:20 PM
UrbanE's Avatar
Default Re: Ecm
4k
I would too
Davidp
Canada
Jan 11, 2022 10:22 AM
413mk
Jul 1, 2020 02:45 PM
texas t
May 19, 2015 09:56 AM
austinbarrylee
May 15, 2015 02:06 PM
Tugwell
Sep 11, 2014 04:41 PM
