Throttle Body Replaced now P0171 & P0174
Old Jan 23, 2023 | 10:49 PM
yorxs's Avatar
Default Throttle Body Replaced now P0171 & P0174
Started having problems with the engine revving to 1500RPM in neutral or in between shifts. A search of the forum conclusively indicated bad throttle body. Ordered the 74mm upgrade from Needswings and the problem totally went away. However the check engine light came on the next day, and I'm throwing P0171 & P0174 lean codes.
Double checking my work, but not finding anything obvious, but certain it is related to the work I just performed and not faulty O2 sensor(s).
Any with advice on how to troubleshoot?
Old Jan 24, 2023 | 12:59 PM
Default Re: Throttle Body Replaced now P0171 & P0174
Did you replace the MAF sensor housing with the larger one, and INSTALL the OLD SENSOR into the new larger MAF sensor housing?
Old Jan 24, 2023 | 10:18 PM
yorxs's Avatar
I was able to locate the cause of the problem. On the top of the throttle body is a nipple fitting that accepts the rubber T with the hoses connected to it. While visually it looked to be installed, I was able to push is down tighter onto the throttle body with a long screw driver, thus making a tight seal. Air was probably leaking past when it wasn't push all the way down onto the throttle body. The check engine light stayed off today and I feel the idle smoothed out a bit.
dcskmail
Aug 26, 2022 01:23 PM
onehundred80
Aug 14, 2011 06:21 PM
DCobray
Jun 18, 2011 04:19 PM
JimmySkullz
Jun 6, 2010 12:22 AM
Banjo46
Jun 24, 2006 06:13 AM
