486 code
Old Aug 4, 2023 | 11:35 AM
Bob54's Avatar
Default 486 code
Trying to find out what this code means, Could not find it any where?
Old Aug 4, 2023 | 12:27 PM
Default Re: 486 code
How did you get it and what exactly did the reader say? That is not a legitimate code that I know of. What kind of reader did you use?
Old Aug 4, 2023 | 04:18 PM
FOund it.
Error 486 Crash - It is called "Error 486" when a program terminates unexpectedly while running (at runtime). This emerges when Windows Operating System fails to respond to input properly, or does not know what output is required in return.
Typical Windows. Anyway, please take your desktop PC questions elsewhere, this is a CAR forum.
Old Aug 4, 2023 | 04:26 PM
Just on a hunch, I tried google.
Advice: Use Google next time:
What does OBD-II fault code P0486 mean? EGR (Exhaust Gas Recirculation) systems are used to reduce the combustion temperature, thus reducing emissions. If the engine control module (PCM) does not detect the amount of flow requested from the EGR, it will set code P0486.
I do not believe that is a supported code in our platform, the Crossfire and SLK320 don't have an EGR "B" circuit. Of course, the manuals have a lot of errors, but I really don't think we have an EGR "B" circuit. What did you read that with?
Old Aug 5, 2023 | 10:13 AM
Bob54's Avatar
Thank you, this code comes on when i start the car, then goes off. When i use a code reader it comes up with no codes. Thank you for your help.
Old Aug 5, 2023 | 10:16 AM
Bob54's Avatar
And by the way, this has nothing to do with windows or a desktop or a laptop. Thank you:[
Old Aug 5, 2023 | 01:00 PM
If it has a little wrench by it, it means you are 486 miles past your next service. It is in your owner manual (FSS).
Old Aug 5, 2023 | 01:43 PM
Bob54's Avatar
Thanks, i will check that.
Old Aug 5, 2023 | 06:08 PM
YEa, NO CODES come up when you start the car. Only the "wrench message" if you are not resetting the FSS when the oil is changed.
jasonk931
Mar 25, 2022 06:22 PM
austinbarrylee
Dec 11, 2013 10:10 AM
BLACKSRT-6
Nov 2, 2009 06:20 PM
Jake80
Jul 17, 2009 11:22 AM
Vmax01
Apr 27, 2009 11:05 PM
