Battery change
Old May 6, 2024 | 01:49 PM
Sfrance1878's Avatar
Default Battery change
Had a new battery fitted along with alternator and it only worked for about 20 miles.
On drive home from garage speedo failed and all brake lights came on and spoiler stayed up.
Had to get it towed back to the garage who can't figure it out and say it's not their fault but an electric fault.
Anyone any ideas please?
Old May 6, 2024 | 02:02 PM
Default Re: Battery change
Have you tried another battery and had the alternator checked. I do not believe in coincidences like this.
Sounds like the alternator failed and you were running on just the battery or vies versa.
Old May 6, 2024 | 02:05 PM
It is a brand new battery and alternator and the garage said they've tried everything I'm no good with cars so wouldn't have a clue
Old May 6, 2024 | 10:44 PM
Have you tried to check the ground from the battery to the frame? Many members have added a separate ground from the battery to the motor/transmission to facilitate a good ground to the electrical system.
Old May 8, 2024 | 08:26 AM
zip439's Avatar
Because you have "no Clue" You best look for an independent garage that works only on european cars and have the car towed there. It shouldn't be hard to figure out what is wrong.
Those that did the install seem incompetent.
kernol2
Nov 13, 2025 04:28 PM
CROSSFIRE MAGGIE
Apr 17, 2017 02:45 PM
scott10301
Aug 24, 2013 04:04 PM
moynah
Jan 12, 2013 07:34 PM
mjgroff
Sep 4, 2011 07:07 AM
