Engine code
Old Apr 28, 2025 | 04:07 AM
Lesdan1958's Avatar
Default Engine code
Have a code p0211 and was wanting to know if someone has had trouble with it.
says throttle actuator stuck?
Old Apr 29, 2025 | 01:30 AM
Default Re: Engine code
Does your scanner recognize your car as a Crossfire or a M-B SLK 320?
I looked up the code and it came up as a fuel injector trouble.
What's happening with the car?
Old Apr 29, 2025 | 08:02 AM
Lesdan1958's Avatar
It said Crossfire.the problem is when you start it sometimes it putts and loads up and if you shut it off and restart it a couple of times it stops doing it.but it will do it to when driving.I put a new crank position sensor in,and have a cam one to put in.
Old Apr 29, 2025 | 08:48 PM
You could be losing fuel pressure.
Check out this thread: Fuel pressure test
It could be anything from a fuel pump, filter, injectors, or even a bad RCM.
You can get a pressure guage from Harbor Freight, Amazon, etc.. they're not expensive.
Bob54
Aug 5, 2023 06:08 PM
jasonk931
Mar 25, 2022 06:22 PM
fric8489
Nov 15, 2021 12:37 PM
austinbarrylee
Dec 11, 2013 10:10 AM
Vmax01
Apr 27, 2009 11:05 PM
