Will these rims work with a Crossfire for snow tires. I've got 17 inch tires. Help?
Old Nov 23, 2005 | 12:47 AM
JBsZ06's Avatar
Default Will these rims work with a Crossfire for snow tires. I've got 17 inch tires. Help?
OEM Factory Mercedes Benz SL500
Quantity: Set of four
Bolt Pattern: 5x112 Offset: 34mm
Help...I need to know if the offset is no good or the rims are too wide..
I have snow tires already waiting to find rims..
Any help would be appreciated?
Do the rims have to be C or slk class?
Will E class rims work?
SL rims?
S rims?
Old Nov 23, 2005 | 12:51 AM
JBsZ06's Avatar
Default Re: Will these rims work with a Crossfire for snow tires. I've got 17 inch tires. Help?
how about these?
SET OF 4 OEM MERCEDES BENZ SL500 17 IN WHEELS RIMS +
You are bidding on an Exceptionally Pristine Set of Four 8.5 x 17 inch Stock OEM Mercedes-Benz 500SL (R-220 chassis) Wheels / Rims (with Center Caps included). 2 of the tires need to be replaced, but the other 2 are brand new-see pictures. These wheels are in incredible condition (see pictures). Below you will find additional Specs:
Rims: 8.5Jx17H2 ET35 7 Spoke, 5 Lugs
Bolt Pattern: 5-112mm
Old Nov 23, 2005 | 12:54 AM
JBsZ06's Avatar
Wheel Specifications:
STAGGERED FITMENT
Diameter: 17"
Width front: 7.5"
Width rear: 7.5"
Offset front: 35 millimeters
Offset rear: 35 millimeters
Bolt pattern: 5 x 112
Finish: Factory Silver
Old Nov 23, 2005 | 01:04 AM
CrossfireLTD's Avatar
Cool Re: Will these rims work with a Crossfire for snow tires. I've got 17 inch tires. Help?
Your original wheels are staggered 18 in the front and 19 in the rear.
roland1226
Mar 22, 2020 07:11 PM
BradenSG
Northeast Forum
Mar 19, 2020 08:52 AM
droptop
Jun 21, 2015 02:42 PM
MJPowers
Jun 8, 2015 02:34 AM
lazorouss
May 29, 2015 08:28 PM
