Radio problem
Old Jan 31, 2006 | 08:40 PM
icefire's Avatar
Default Radio problem
I have tried to use the search option but I can't find the answer. I live in Iceland and I got my Crossfire from Florida last wednesday. After shipping, the car was ok, but I think the tariff staff have do something wrong because when I got the car I could not started because the battery was empty. After I recharged the battery the radio was totally frozen. This is Infinity stuff with navi and green screen. All the buttons are frozen, but the only thing I can do is load a CD and listen, I can't change the volume or change a song.
I am not very strong in english, sorry about that.
Old Jan 31, 2006 | 10:56 PM
RowdyRoadster's Avatar
Default Re: Radio problem
TRY a software reset.
Press and hold the opt button, the first multi function button, and the third multi function button all at the same time. The multifunction are the ones at the bottom of the display.
OPT, 1 , 3
If it doesn't respond to that then i'd try a good ol hard reboot.
Disconnect the negative battery cable from the battery to make sure there is no power going to the radio at all. Let it sit for a few and then reconnect the cable. Test the radio...
Hope one of those helps.
Old Feb 1, 2006 | 08:43 PM
icefire's Avatar
Thanks a lot, the second advice worked. But now I have a new problem, if I double lock the car the radio turns on after a about 1/2 minute?
Old Feb 2, 2006 | 12:29 PM
CrossfireLTD's Avatar
Cool Re: Radio problem
Try this...sit in the car and use the console buttons to lock the doors, if the radio comes on again then there is an electrical problem, if it does not come on then there is a problem with the key transmitter may be the problem.
Old Feb 2, 2006 | 05:22 PM
icefire's Avatar
Angry Re: Radio problem
The radio is frozen again. I think I let the dealer plug the car to his repair computer.
Old Jan 20, 2014 | 12:06 PM
B1gfun's Avatar
I know this is a very old thread. Was there a fix that worked? My stereo just did this today. Its frozen and says "CHRYSLER" on the screen. I cant turn it on or off. No buttons work and neither does the volume or station dial. It also stays on for some time after i shut the car off. It did turn off for a time while I was driving on its own, but did come back on still in the frozen mode. Any help?
A little back ground: everything was working fine until I pushed the gps button and put in the gps disk to play with.
Old Jan 21, 2014 | 10:07 AM
B1gfun's Avatar
update: I dorve home and the steroe was still frozen on and nothing works . (buttons or dials cant turn on or off). Turned the car off and the stereo wouldnt shut off. i let it sit and it was still on when i came back out. I pulled the #5 fuse and it didnt shut off. I pulled the # 8 fuse and it shut off. I left it that way for a few minutes. Plugged it back in expecting the stereo to continue to be back on even thought the ignition was off. It didnt. Everything seems to be back to normal. Quick fix. We'll see how long it lasts.
Anyone else experience this phenomena?
Old Jan 21, 2014 | 03:38 PM
KrisFire's Avatar
I personally have had this happen to me, but turning the car off/on eventually fixed it. Here is a thread that has some solutions.
Old Jan 21, 2014 | 03:45 PM
B1gfun's Avatar
Thanks KrisFire! I had read that post. Just seems odd that this happens. Wondered if anyone knew why it happens. Hopefully my fix works. I did it last night and only drove to work today. I checked it at lunch and all was good, we'll see on the ride home. Thanks!
Old Feb 17, 2014 | 10:25 AM
redfire2005's Avatar
I can tell your from much knowledge: Don't remove the radio without removing the negative terminal cable.
It sound like it needs to be reprogrammed- don't panic. it is a combination buttons on the radio. I don't know them right now, but there are guys here that can lead you to them. If I am right, I believe it is because the battery was removed for all the time and memory in the radio cleared itself.
This is a thought I am having, but again there are much better tech assist guys on here that can help you.
pioneer4x4
Sep 18, 2023 11:49 AM
PNA
Nov 12, 2020 04:44 PM
reiji
Oct 15, 2015 10:50 PM
x1xsinisterx1x
Aug 24, 2015 07:31 PM
pioneer4x4
Jul 27, 2015 02:04 PM
