New head unit radio sub help.
Old Mar 13, 2006 | 06:36 PM
stryfox's Avatar
Default New head unit radio sub help.
Ok I am working on a new headunit for my xfire.
I want more sub control.
I am looking at a head unit with a sub. pre out, and sub control
Can I just get a two channel amp and hook it up, running the sub pre out to it then running the powered wires directly to the factory subs, Of course I will need to disconnect the wires from the facctory amp to the subs.
I hope I am making sence, It is hard to type what I am trying to say.
What amp should I get?
Any better suggestions? That won't cost tons of $$$
Thanks
Old Mar 13, 2006 | 07:32 PM
ben's car audio's Avatar
Default Re: New head unit radio sub help.
You should be able to divert the sub wiring at the factory amp under the passenger foot plate. The subs have (2) two ohm voice coils per, if I remember right. so if you wire each woofer in series then parallel the left and right you would end up with a single two ohm load that would be acceptable to alot of monobloc amps nowadays. Make sure your amp is capable of a two ohm "mono" load. this diagram should help: https://www.crossfireforum.org/forum/...ead.php?t=9057
Old Mar 13, 2006 | 07:44 PM
stryfox's Avatar
Thanks ben you rock!!!
I am actually waiting for the pioneer avic-z1 to release.
I converted the dash to a double din, moved the switched to the center a/c vent.
I'll post some pics soon.
I just don't like the flip up displays.
Should I just get a 4 ch. amp and replace the factory one all together?
Thanks for yours help.
Old Mar 14, 2006 | 03:42 AM
By going to a larger four channel amp and bridging two channels for your bass and running the other two stereo it would keep things simpler - but if you are like me and pretty much run it wide-open all the time it may not give you that much more volume: a simple rule of thumb with amplification is, if all other parameters remain the same and you just double the available power then you will net an increase of 3 decibels. 3db is just over the minimum threshold that human hearing can hear a difference - you see where I'm going ? Now if you keep the stock amp on the top end and run a separate big mono amp on the bottom then two things will be influenced ... The top-end will be able to run much cleaner because the common power supply will no longer have to perform double duty of running all the output devices - just the ones running high frequency. The new monobloc has it's own power supply that won't effect the signal reaching the mids and tweeters - so you can run the bottom end really hard (distorted) before you will even hear it. If I can I always try to split up the power supplies feeding the top and bottom for these reasons.
Old Mar 14, 2006 | 11:05 PM
stryfox's Avatar
Thanks again, this makes sense. I'm going to give it a try.
Now I just need to get a hold of a pioneer avic-z1.
The wait is killing me, I was told mid april by pioneer.
I just need to find out who is getting them so I can order one.
minimayhem
16
Aug 23, 2016 07:47 AM
smokey847
Nov 12, 2015 11:54 PM
RacerXofFL
Sep 15, 2015 05:00 PM
smokey847
Sep 15, 2015 10:47 AM
rdougc
Sep 5, 2015 10:30 PM
