Modified Jaguar XK8 Intake on a XF?
Old Mar 15, 2006 | 10:41 PM
jpristel's Avatar
Default Modified Jaguar XK8 Intake on a XF?
Since no performance intakes are designed for our cars, I started looking around at various engine designs and noticed that the Jag XK8 intake seems to attach in a similar position to our cars', there are also a few companies producing performance intakes for the XK8...
Just a thought.
Anyone know of any other cars with the intake at the rear of the engine block?
Old Mar 15, 2006 | 11:01 PM
xfire1's Avatar
Default Re: Modified Jaguar XK8 Intake on a XF?
j.
nice research...
thanks
j.
Old Mar 15, 2006 | 11:22 PM
former NXMX5's Avatar
you could also use an E500 intake on the XF, and the SL55 intake on the SRT6, from what i've read --
Old Mar 15, 2006 | 11:43 PM
stryfox's Avatar
It is not that hard to make your own.
https://www.crossfireforum.org/forum...ead.php?t=9375
Old Mar 16, 2006 | 09:59 PM
jpristel's Avatar
I've made a few intakes before, however the best performing intake I've had was one that had molded plexi-glass around it so that it drew in air from behind the headlight and from the inside of the fender well only. I sealed the intake from the warm air inside the engine bay.
http://www.3800performance.com/Merch...roduct_Count=2
I'm probably going to do something similar to that again. Very simple, but very effective...
Many companies sell "cold air intakes" that actually won't draw in any cold air what so ever. Simply putting a bigger air filter under the hood does not make a CAI, air has to be directed from outside the engine bay into the air filter otherwise you'll see minimal gains if not a loss in HP.
Has anyone tried a "cool can" before? One of my buddies that does some professional racing recommended one of these to me...
Old Mar 16, 2006 | 10:32 PM
woody's Avatar
Originally Posted by jpristel
I've made a few intakes before, however the best performing intake I've had was one that had molded plexi-glass around it so that it drew in air from behind the headlight and from the inside of the fenderwell only. I sealed the intake from the warm air inside the engine bay.
Many companies sell "cold air intakes" that actually won't draw in any cold air what so ever. Simply putting a bigger air filter under the hood does not make a CAI, air has to be directed from outside the engine bay into the airfilter otherwise you'll see minimal gains if not a loss in HP.
I'd agree with everything you say about CAI's. As I mentioned in a previous thread regarding the testing I did on my PT, the stock wheel arch inlet provided the coolest air, and the hottest was where the 'CAI' kits mount. See 'engine compartment 1' compared to the 'airbox' traces on the graph below:
Sep 28, 2015 07:40 PM
Ralph289
Sep 21, 2015 09:34 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
Idrenak
Sep 19, 2015 08:17 PM
68Nova
Sep 18, 2015 09:44 PM
