I Pod connections help
Old Dec 25, 2006 | 08:14 AM
kardiac's Avatar
Default I Pod connections help
I have an '05 LTD and would like to get a direct connection for my I pod, I still have the factory installed Infinity stereo system and would like to leave it in. Is there any way this can be done without changing the radio system, and if so what should the cost range be ?
Old Dec 25, 2006 | 10:08 AM
Default Re: I Pod connections help
Try this link. You will find it here, Someone on this forum wrote that it is available in the US, but I was not able to find it local.
Hope this helps.
http://www.ipodcarkitdirect.co.uk/iP...k_Plus_Adapter
Old Dec 25, 2006 | 09:40 PM
mjanowich's Avatar
I upgraded to a new head unit that has the iPod controls on the front of the head unit itself. I know most of the major brands have iPod compatible units now, but mine is an Alpine. The head unit was about $350 and the iPod cable was around $20. The only problem I have with it is that there is no "menu" button when you are listening to a playlist that will list the playlist again. Other than that, it works like a charm. I've never had a CD in the thing since I installed it. I always use the iPod.
Old Dec 27, 2006 | 01:02 PM
pgmikes's Avatar
Here is the FM Modulator I installed in my car. It connects directly in the car antenna (so we also need the converter kit). It worked out great; the device filters out the unwanted signal coming thru the car antenna. It all fit behind the dash under the stereo.
http://www.installer-data.com/item/d...php?it=FMM-100
http://www.installer.com/item/displa...php?it=40-sb30
http://www.installer-data.com/item/d...hp?it=IPOD-RCA
VW / Audi / Mercedes Radio Removal Tools
http://www.installer.com/tools/#
Old Jan 16, 2007 | 12:04 PM
Irafatsar's Avatar
[quote=FP]Try this link. You will find it here, Someone on this forum wrote that it is available in the US, but I was not able to find it local.
Hope this helps.
http://www.ipodcarkitdirect.co.uk/iP...k_Plus_Adapter[/quote
04 crossfire I pod compability
Michael,
The only option currently available for your car is the iPod FM Modulator. The difference between this and the radio specific iPod Kit is that you cannot control your iPod from your radio or steering wheel controls. But it does charge your iPod as the ice>Plus does.
On the plus side these are about £30 less than the radio specific ice>Link Plus kits. Also please do not confuse these with FM Transmitters that are of inferior quality to the hard wired Dension ice>Link FM Modulator. The Dension ice>Link FM Modulator is a hard wired product meaning that all interference is elimated.
We used to sell the cheap FM Transmitters but had a returns rate of close on 70%, so beware!
View the ice>Link FM Modulator hear:
http://www.ipodcarkitdirect.co.uk/iP...k_FM_Modulator
*Please note the cradle is incompatible with the 30GB Photo iPod and you will need to order a dock cable with it instead.
Also to mount this to your dash you'll need a damage-free mounting bracket specific to your car make and model.
View these here:
http://www.ipodcarkitdirect.co.uk/iPod_Mounting/
Regards,
Support Team
P.S We offer a unique 30-Day Money Back Guarantee - See the details at: http://www.incar-support.com/esuppor...tion%3C%2Fa%3E
Ticket Details
Ticket ID: EQB-60294
Tracking URL: http://www.incar-support.com/esuppor...b&_i=EQB-60294
Department: 1: Pre-Sales Enquiries
Created On: 13 Jan 2007 02:49 AM
Last Update: 13 Jan 2007 02:49 AM
Status: On Hold
<ticket no="EQB-60294"/>
think I need a new car that comes with an Ipod adapter built in..............not
All the new replacement heads i have seen dont look as good as the original. and I am getting tired of changing cd's
o55ie18
Oct 5, 2015 05:50 PM
bbsrt6
Sep 19, 2015 11:21 AM
tritongreen
Sep 18, 2015 07:32 AM
RiderJC
Sep 7, 2015 11:19 PM
jaesa
Sep 7, 2015 01:50 PM
