Stock Amp Rear Channel Cutoff
Old Jun 6, 2010 | 07:30 AM
sive81364's Avatar
Default Stock Amp Rear Channel Cutoff
Does anybody know what the stock amp rear chanel frequency cutoff is? I am installing a new system and want to know if I can use the stock amp to drive a pair of Alpine SPR-17s Component Speakers . I want to use the front 2 chanel for the tweeters and the back two for the 6.5's. Is the possible or is the amp cutoff so low all I will get is lows and no mids.
Thanks for any help
Sive
Old Jun 7, 2010 | 12:11 PM
ehowarth's Avatar
Default Re: Stock Amp Rear Channel Cutoff
The stock amp has 4 input channels and 6 output channels. Each subwoofer input channel controls 2 output channels. There is no crossover network in the amp. All channels are full range. See the wiring diagram for details.
Old Jun 10, 2010 | 02:56 PM
Airscape's Avatar
When I installed my new HU and tested i found the amp does limit the rears. I went preout to the amp for both front and back. Regardless of what output I hooked the rears to all I got was lows.
Old Aug 1, 2011 | 04:58 PM
mikeandyance's Avatar
how can i wire the rca jacks straight into the amp??? back subs dont work ..connector broke...what color are the rear subs on the amp clip?
Old Aug 1, 2011 | 08:30 PM
redeagle's Avatar
I found the same thing as Airscape
velociabstract
Aug 7, 2015 01:30 PM
MAXIMUM
Aug 4, 2015 11:04 PM
mobilefitt
Jul 28, 2015 03:45 PM
tom2112
Jul 28, 2015 08:12 AM
pioneer4x4
Jul 27, 2015 02:04 PM
