R/H Drivers Window Switch?
Hi all,
I have an 04' Coupe non SRT and have been having issues with the R/H Drivers window temperamentally not working. It opens then stops working and then doesn't work at all. When you disconnect the battery it will work for a few seconds and I have also replaced the car battery today as the car needed a new one due to cold weather.
I think I may need a new switch. Does anyone have one or know what the part number is? Even better, does anyone know if there is a Mercedes SLK300/320 on which will clip straight in? Thanks in advance for your help!
Dave from Hampshire, UK
I have a similar problem on my '05. The drivers' window will go down, but not up. I replaced the regulator, removed the motor and tested it on the other door and it worked, and swapped the left switch for the right switch. It also worked. Is there a clicking noise when you press the button? There is on mine. Something seems to be faulty between the switch and the motor. If anybody is familiar with this, please let me know. This may help us both.
Thanks
Thanks
xfireohio
Jul 20, 2020 12:03 AM
pioneer4x4
Jul 27, 2015 02:04 PM
axnguyen
Jul 21, 2015 11:41 AM
