Kenwood D558BT
Old Sep 3, 2014 | 02:19 PM
antwaun42's Avatar
Default Kenwood D558BT
Hello All,
Just starting off by mentioning that this forum has been my number 1 resource when it comes to my recently purchased Crossfire. I'm finally upgrading to an aftermarket radio, and i'm running into a bit of an issue. I've searched near and far for the answer, and i'm sure its fairly simple, but I wanted a definite answer before going any further.
I purchased the Kenwood D558BT and am attempting to install it. I also bought the Metra 70-1786 harness, due to the Schosche brand not being in stock at any of the stores near me. I ran into a problem with matching up the wires correctly. I have read that there is no need to interchange the yellow and red wires, so I think i'm good there. The issue i'm having involves matching up the Orange wire from the Metra harness to the Kenwood, which has no Orange wire coming from it. The wire labels were also removed from the Kenwood's wires, so i'm clueless as to what should be labeled as what. After matching up the red, black, and yellow wires from each, there is an orange wire remaining from the Metra, and two wires from the Kenwood which are blue and blue/white. There is a brown wire coming from the Kenwood, but i'm sure that it is the Mute wire, which I don't think I need.
I have tried hooking it up a couple of different ways, and although I get the display to come on, I still get no sound. I have also been through the options screen on the Kenwood to see if there were any settings that were muted. I am in a 2004 CF with the 2 door speakers and 2 rear subs... Any help would be greatly appreciated!
Old Sep 3, 2014 | 04:24 PM
Speedy4x4's Avatar
Default
The orange from harness is for the illumination.
The blue and blue white wires are for power antenna and the amp control wire.
I am pretty sure.
I will double check when I have some time later.
I have this same head unit in my ssb. And love it.
Old Sep 3, 2014 | 04:51 PM
austinbarrylee's Avatar
Default Re: Kenwood D558BT
ok I can help I just received mine today. blue wire is ant cont. blue and white wire is P. cont. light blue and yellow wire the marine remote. brown wire is the mute. those are the labels on the wires.
Old Sep 3, 2014 | 04:59 PM
http://manual.kenwood.com/files/GET0995-001C.pdf
Old Sep 3, 2014 | 05:03 PM
antwaun42's Avatar
Thanks for the speedy replies guys.... I will make note of these labels and see if I can get things set up this evening.
Old Sep 3, 2014 | 05:06 PM
please keep posted on how you wired. I am going to wire mine. I know others have talked about wiring into amp.
Old Sep 3, 2014 | 05:09 PM
antwaun42's Avatar
I will be sure to let you know. I just want the sound and everything to work correctly from the Kenwood. I looked into wiring into the amp, but the setup looks a bit difficult, so i'm just taking baby steps for now.
Old Sep 5, 2014 | 04:19 AM
Oconnom's Avatar
Question Re: Kenwood D558BT
Hi,
I'm torn between the Kenwood 558 and 308 units. Main difference is pre-outs. 558 has loads and 308 only one. As I have no intention to replace the stock amp, do I need the extra pre-outs on the 558 ? Also, I seem to remember that the OEM amp requires direct speaker outputs to drive it ? If correct, no requirement for pre-outs ?
Are the speakers behind the seats subs or just basic bass speakers ?
Mick
psuperti
Feb 24, 2020 10:26 AM
psuperti
Aug 30, 2015 12:08 PM
ldare2000
Aug 17, 2015 09:41 AM
pioneer4x4
Jul 27, 2015 02:04 PM
pioneer4x4
Jul 21, 2015 10:35 PM
