Infinity Stereo just clicks, no sound
Old Apr 14, 2020 | 11:15 AM
Sterling157's Avatar
Default Infinity Stereo just clicks, no sound
Hi all.
I have a 2006 Crossfire Coupe.
When I turn the stereo on, it seems to read CD’s and find Radio stations etc but no sound comes from the speakers, except a clicking sound.
See video below, please help
TIA
Old Apr 14, 2020 | 06:56 PM
Default Re: Infinity Stereo just clicks, no sound
YOu have an 06 - ok, Base, Limited or SRT (there were only like 20 06 SRTs, but I thought I'd ask anyway)?
I ask because Base models have no amplifier but all others do - if you have a Base, you simply need a new radio 'head unit'.
Ok, so the radio is powered up and appears to be more-or-less working.
What about the amplifier? If you have an SRT or Limited (or any 04) model, you have an amp under the passenger footwell. In most model years, Fuse 23 is the "booster" or amplifier fuse; this is fuse 23 in the underhood fuse box on the driver's side. Verify that fuse is not blown. You say you have an 06, most 06s are Limiteds but some are Base or SE - Base and SEs have no amp - the ONLY thing that can be wrong is the head unit - REPLACE IT!
Base Roadsters and Coupes are: Black inside and out, lack power/leather seats, fog lamps, tire monitor, garage door opener, etc.
Next, you need to get under the passenger floor mat, and determine if water has flown under there - destroying the amp. This is common, when the drains under the wipers get plugged with leaves, rain will back up and overflow and get down into the area behind the dash, then run down and get the amp wet. Should the amp not have been wet, it could be the amp died anyway - or it can be that the radio "head unit" has simply failed. You can use a test speaker (any speaker with wires connected to it) to test the head by stripping the ends of wires on teh test speaker and inserting them next to pins of "speaker outputs" on the back of the head to determine if the head is working or not. If it makes the test speaker work, then the amp in the car is the issue.
New aftermarket Kenwood/JVC/etc. heads cost as little as $85 - and are easy to install. Aftermarket amps are reasonably priced from $75 to over $500.
Old Apr 14, 2020 | 06:57 PM
A lot of service information on the factory-installed amp is here:
https://www.crossfireforum.org/forum...-channels.html
Old Apr 15, 2020 | 04:38 AM
Many thanks.
I have the Limited (don’t think the Base models were sold in the U.K.).
I will check the amp.
Old Apr 15, 2020 | 09:57 AM
I have a RHD, so when you say the passenger side floor mat, I am presuming on mine it would be the drivers side.
Would I be right in saying that?
Old Apr 15, 2020 | 05:59 PM
That is an interesting question. I believe the amp is located in both passenger (LH & RH) sides (been wrong before but it should be easy to check in the downloadable service manual here). Let us know for future posts?
Old Apr 15, 2020 | 06:20 PM
I would think that on a manual it wouldn't be too good to be pressing the clutch into the steel plate holding the amplifier,
but then I've been wrong before.
salas112
Oct 27, 2017 05:23 PM
popeye
Apr 10, 2010 03:20 PM
Rennie Mihalovic
Jan 28, 2010 11:12 AM
kyzersosei
Sep 28, 2004 06:55 PM
vegas007
Jun 20, 2004 04:01 PM
