Shift Knob Survey
Old Oct 28, 2006 | 04:12 PM
Question Shift **** Survey
Survey; Which of the following do you like best: L - R 1, 2, 3, 4, or 5?
I assume that for 4, I will need to keep the base/bottom part of the XF's ****?
Old Oct 28, 2006 | 04:43 PM
Thirteendog's Avatar
Default Re: Shift **** Survey
E none of the above. I actually really like the stock one, but if you like one of these go for it and be different.
Old Oct 28, 2006 | 05:38 PM
patpur's Avatar
Senior Member/Moderator
Agree with Thirteendog, a little to busy for my taste. I too am very happy with the stock shifter. But then again its not us you have to make happy.
Pat
blacklimitedcoupe's Avatar
I like #1 and 3, but I've seen some that I like even better than those 4... I really like this one...
Old Oct 28, 2006 | 05:44 PM
midnightman's Avatar
Add me to the "I like the stock **** best" list. Especially here in south Florida where the sun can turn a shift **** into branding iron, the plastic stock shifter never gets too hot to handle.
Old Oct 28, 2006 | 05:54 PM
Yep, I appreciate the comments on keeping it simple. I personally don't like accessories that make the car too busy, but the stock **** blends right into the aluminum trim. There's no contrast. If the head was leather to match the seats, I would like it, but it's all one color.
Old Oct 28, 2006 | 07:08 PM
+fireamx's Avatar
I'm with Patpur and Midnightman, I happen to like the "feel" of the stock shifter ****. I do have to admit though, my hand has slipped off of it a couple of times when I was in too much of a hurry. But then mines a manual.
#3 looks alot like the head of a microphone, but it does look like it would be the least likely to slip out of your hand.
Old Oct 28, 2006 | 08:38 PM
I apologize for the mix up of the pictures, but in an attempt to edit this, I shuffled them around.
Old Oct 28, 2006 | 08:59 PM
The Toy's Avatar
What I'd like to have is a shifter that was more straight up when I have it in drive. I find that in drive the level leans back just a bit to far and my arm is bent back while resting on the console and my hand on the shifter. Plus the level is at like a 30 or so degree angle and my hand is only on the top. If anyone has a suggestion of a brand that would help correct this, please post the info or link.
Thanks.
Old Oct 28, 2006 | 09:02 PM
Sidez's Avatar
The second one is my choice.
Old Oct 28, 2006 | 09:08 PM
I guess since you added one more I must choose F for None of the above instead of E. They all look like they would be ok, but I just hope you don't go with the Eight Ball or the Skull shifters. Now, that would be Whack.
Old Oct 28, 2006 | 09:12 PM
LOL, that was funny...
Old Oct 28, 2006 | 09:53 PM
Originally Posted by FPMartinez
...but the stock **** blends right into the aluminum trim.
That's actually another of the reasons why I like it best. Along with the continuation of the "spine" through it.
All my previous cars had a leather shift **** that had no real visual association to the rest of the interior, so changing those didn't change the theme. This is not the case with the Crossfire. In fact, I don't know of ANY other car that has the unique feature of a truly matching shift ****.
But this is just my opinion. I have no problem with anyone that feels otherwise. To each, their own.
Old Oct 28, 2006 | 11:29 PM
MAYAman's Avatar
I like the original ****.
Old Oct 29, 2006 | 08:45 AM
marauderroy's Avatar
I like the stock **** but #1 looks good too.
Old Oct 29, 2006 | 09:45 AM
Iamfink2's Avatar
I like the stock one also but if I had to choose one I'd pick number one.
Old Oct 29, 2006 | 10:35 AM
andrew's Avatar
-C-I-C-C-I Associate Member
~ do you like the leather one i have? possibly another option for you. it looks very factory imo... b/c its a m/b slk ****.
Old Oct 29, 2006 | 12:55 PM
John Webster's Avatar
If you've got an automatic it's a transmission mode selector and you can do what you please with it.
On a manual it's a shifter **** and it works and looks just fine.
Old Oct 29, 2006 | 04:09 PM
Well excuuuse meee...
Old Oct 29, 2006 | 05:00 PM
well i think andrew's "transmission mode selector" looks very nice.
