Try this, see if your xfire does this
Old Nov 1, 2006 | 11:48 PM
alfdoc's Avatar
Question Try this, see if your xfire does this
With the key out of the ignition, with the blower switch in the off position, push the air recirculation button below the air-conditioning button. My blower turns on , does yours ?
Old Nov 1, 2006 | 11:50 PM
markr6754's Avatar
Default Re: Try this, see if your xfire does this
Originally Posted by alfdoc
With the key out of the ignition, with the blower switch in the off position, push the air recirculation button below the air-conditioning button. My blower turns on, does yours ?
That's what it's designed to do. Same with the radio...the idea was to keep the car hot or cold depending on settings for grandma while you run into the store. Supposed to lat an hour.
Old Nov 1, 2006 | 11:52 PM
dontlietokids.net's Avatar
Well there's a feature I didn't know about!
Old Nov 2, 2006 | 12:17 AM
blacklimitedcoupe's Avatar
I believe it only stays on for 15 minutes. You can also use it in humid weather to prevent the a/c from smelling bad next time you get in.
Old Nov 2, 2006 | 12:40 AM
dynamicS's Avatar
it works well to clear out the excess water moisture out of the A/C system when you park.
Old Nov 2, 2006 | 04:18 PM
greenie's Avatar
Just imagine what you would find if you actually read the manual...
Old Nov 2, 2006 | 10:43 PM
stryfox's Avatar
I use it when it is cold out and I run into the store to get my coffee or something.
I like this feature a lot.
Old Nov 2, 2006 | 11:17 PM
markr6754's Avatar
Smile Re: Try this, see if your xfire does this
I'll admit...I was tempted to make the same comment...but I realized the person making the response is new to the board (2 posts), so I deferred. I remember when I was new...to the board. However, I've also seen that many new owners of their used Crossfires didn't get the owner's manual.
Old Nov 2, 2006 | 11:55 PM
Sennaspirit's Avatar
Manual? We don't need no stinkin' manuals!
Old Nov 3, 2006 | 06:39 PM
Wayne1992's Avatar
Apparently Chrysler thought I would be better suited with a Pacifica manual than a XF manual. I did discover the wrong manual before I left the lot and they got me the correct one but never took back the wrong one...so I read both of them! Well, mostly just looked at the pictures!
Blackktieguy
21
Oct 26, 2015 12:32 AM
xfireon20z
Sep 10, 2015 04:27 PM
Caught in a Xfire
Sep 5, 2015 05:20 PM
Caught in a Xfire
Sep 4, 2015 10:14 AM
Crossfireone
23
Aug 25, 2015 04:56 AM
