VIN translation
Old Jan 30, 2007 | 12:33 AM
MYCROSS's Avatar
Default VIN translation
Does anyone know the difference in a 5 series and 6 series roadster or coupe for that matter? This is the 6th digit in the Vin according to the manual. Where is the paint color code located and does anyone know where to go for the translation? Is there a site you can go to for this info?
Old Jan 30, 2007 | 09:44 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: VIN translation
~ here is the link for a bmw vin decoder: http://www.bmw-z1.com/VIN/VINdecode-e.cgi
~ the paint code can be found on the core support, drivers side strut housing or drivers door jamb... depending on the type of bmw.
~ this is one of my favorite bmw sites: http://www.roadfly.com/bmw/forums/
hope this helps!
Old Jan 30, 2007 | 10:33 AM
MYCROSS's Avatar
Thanks Andrew but BMW data does not cross reference Crossfire. Your attempt to answer is appreciated.
Old Jan 30, 2007 | 12:23 PM
Romio's Avatar
i guess when you said 5 series and 6 series, you meant BMW, because that's what they are called. do you mean 2005 and 2006 series?
Old Jan 30, 2007 | 12:35 PM
C_Plunkett's Avatar
This was posted somewhere else on the forum. I'm not sure of the source.
VIN decoder by digit:
1 Country of Origin 1 = Manufactured By DaimlerChrysler Corporation
2 Make C = Chrysler
3 Vehicle Type 3 = Passenger Car
4 Other K = Restraint System Front & Side Air Bags
5 Car Line N = Crossfire (LHD) P = Crossfire (RHD)
6 Series 5 = Base 6 = Ltd 7= SRT6
7 Body Style 5 = Roadster 9 = Coupe
8 Engines L = 3.2L V6 SOHC 18 Valve N = Superchg V6
9 Check Digit See explanation in this section
10 Model Year 5 = 2005 Model Yr.
11 Plant X = Osnabrueck Germany
12 -17 Sequence Number 6 Digit Sequential Number Assigned By Assy Plant.
Old Jan 30, 2007 | 12:36 PM
andrew's Avatar
Red face Re: VIN translation
~ exactly what i thought... i'm a bmw guy so i just assumed the language.
Old Jan 30, 2007 | 05:09 PM
Rydiak's Avatar
Heh, I assumed the same. I too was going to google for BMW VIN decoders, and then ask the OP why this was in the Crossfire forum. :P
Old Feb 22, 2007 | 12:34 AM
BillP2R's Avatar
Anyone know what an A in the fourth position (instead of a K) means?
None of the VIN decoders I've seen mentions the possibility of an A, but on my '04 coupe it's an A.
- Bill
Old Feb 22, 2007 | 12:52 PM
wocar's Avatar
The attachment contains the vin chart from the 2004 parts cd. You will notice that the assembly plant in position 11 is incorrect.
https://www.crossfireforum.org/forum...1&d=1172166541
File Type: doc
Old Feb 22, 2007 | 06:59 PM
BillP2R's Avatar
Thank you for the info.
This makes sense, but I wonder why the service manual shows a K for the same SRS sytem configuration.
Maybe it's a German thing.
- Bill
Old Feb 22, 2007 | 07:32 PM
Rydiak's Avatar
Oddly enough, my SRT-6 has an 'A' instead of a 'K'. Gotta love the Germans.
Geechee1962
Sep 16, 2015 05:33 AM
da pink
Aug 12, 2015 05:20 PM
FiftyThree033
Jul 26, 2015 09:24 PM
oledoc2u
Jul 21, 2015 07:08 PM
Bayukbros
Jul 17, 2015 04:22 PM
