Battery maintainer ??? Hook up ???
Old Feb 23, 2007 | 11:32 AM
vet4scuba's Avatar
Talking Battery maintainer ??? Hook up ???
Hi,
I get the idea and the reason to use but...
1. Do I leave the battery in the car with all the battery cables hooked up & attach the maintainer with the alligator clips ???
2. Or should I disconnect the positive and negative cable then attach the battery maintainer ???
Old Feb 23, 2007 | 05:35 PM
marauderroy's Avatar
Default Re: Battery maintainer ??? Hook up ???
Leave the battery hooked up, Just use the clips and plug it in. That's what I do with my Crossfire and my motorcycle. Never had any trouble with that setup.
Old Feb 23, 2007 | 06:29 PM
crossfirefrank's Avatar
Leave in car and hook-up. I done this and it works well.
Old Feb 23, 2007 | 09:35 PM
Maxwell's Avatar
Don't forget to do the maintenance on the battery's electrolyte. I just checked my caps an a couple where really low.
Old Feb 24, 2007 | 02:29 AM
mhweller's Avatar
Why use it at all go start the car once a month or every other week that is actually much better for the battery than a maintainer system. You will get oil to the top end and re-lubricate parts that are otherwise sitting there with no oil and developing a rust coating trust me don't let your car sit for 3 or 4 months without running the engine unless you fog it like a boat motor.
Old Feb 24, 2007 | 08:13 AM
My brother-in-law works for Chrysler proving grounds as a mechanic and he is the one that advised me NOT to start the car every month. !st he told me the car would have to run at least 1/2 hour to warm it enough to keep moisture from condensation after you shut it off. 2nd he told me your cylinders are as dry in a month as they are in 6 months. He also advised me to jack the car off the ground, better for suspension and avoids flat spots on tires.
blackpepper
Oct 4, 2017 06:09 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
o55ie18
Oct 5, 2015 05:50 PM
JEFASOLD
Sep 28, 2015 12:10 PM
Valk
Sep 17, 2015 11:43 AM
