Eibach springs vs tire wear
Old Mar 6, 2007 | 01:52 PM
Maxwell's Avatar
Default Eibach springs vs tire wear
To those of you who installed the Eibach lowering springs, how have your tires been wearing? Has tire wear evened out across the entire surface or do you still get more wear on the outer edge?
Can someone tell me who makes the camber adj kit for our cars? I thought there was a company in Australia that made them?
Old Mar 6, 2007 | 02:48 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Thumbs up Re: Eibach springs vs tire wear
my first set of conti all seasons lasted over 25k (lowered at 1k)... and i had even wear across the entire tread... front & rear... with no camber adjustment components installed.
Old Mar 6, 2007 | 05:50 PM
norrie's Avatar
Default Re: Eibach springs vs tire wear
You should really get your suspension realigned whenever you change anything.
i.e get a four wheel alignment.
This ensures everything is running straight.
Norrie.
Old Mar 6, 2007 | 07:13 PM
Maxwell's Avatar
Norrie.
sorry man, but there is no adjusting the IRS on this car.
Old Mar 7, 2007 | 12:09 AM
MAYAman's Avatar
so did I and same result.
Old Mar 7, 2007 | 03:39 AM
+fireamx's Avatar
Andrew, I wondered how your tires were wearing ever since I followed you back to Ohio on the Turn Pike last summer.
Your IRS did indeed seem to have more "negative" camber to it than my stock one does. I just attributed it to your use of "spacers".
Glad to hear it hasn't caused you any increased tire wear.
Old Mar 7, 2007 | 09:15 AM
andrew's Avatar
i now have added 8k miles to the tires since last july... no inside wear on the rears... but indeed quite a bit of negative camber. however...the negative camber is the same with or without the spacers.
Old Mar 7, 2007 | 09:28 AM
+fireamx's Avatar
Wow, I'm not going to get anywhere near that many miles on my original all season tires. I don't go around "burning" em up either, and I always keep them properly inflated also.
They are wearing evenly though.
Jonacross
20
Jul 17, 2017 11:19 PM
onehundred80
Aug 6, 2016 12:03 PM
UNDER PSI
Nov 1, 2015 09:39 PM
ayebb
Sep 18, 2015 03:35 PM
caseydeankopp
Sep 13, 2015 07:25 PM
