Vin # POSITION INTERPRETATION CODE = DESCRIPTION
Old Jul 22, 2007 | 06:13 PM
Default Vin # POSITION INTERPRETATION CODE = DESCRIPTION
The following is an almost complete explanation of the vin#. The last six digits are assigned by the manufacturer as a sequence number.
1 Country of Origin 1 = Manufactured By DaimlerChrysler Corporation
2 Make C = Chrysler
3 Vehicle Type 3 = Passenger Car
4 Other K = Restraint System Front Air Bags Next Generation, (CGW) With Standard Side Air Bag Supplement (CGS)
5 Car Line N = Crossfire (LHD), P = Crossfire (RHD), 6 Series 6 = “S” Series
6 Export Transmission C = 6 Speed Manual (DED), E = 5 Speed Automatic (DGU)
7 Body Style 9 = Specialty Coupe
8 Engines L = 3.2L V6 SOHC 18 Valve
9 Check Digit See explanation in this section
10 Model Year 4 = Model Year
11 Plant X = Osnabrueck Germany
12 through 17 Sequence Number 6 Digit Sequential Number Assigned By Assembly Plant.
Old Jul 22, 2007 | 10:11 PM
62thunderbird's Avatar
Default Re: Vin # POSITION INTERPRETATION CODE = DESCRIPTION
I was under the impression that the 6th digit was the trim code. 5=base, 6=Limited, 7=SRT
7th digit was the body style. 9=coupe, 5=roadster.
Old Jul 22, 2007 | 11:22 PM
wocar's Avatar
Only export models used position 6 for transmission identification. US models used position 6 for the series (there was only one in 2004). For 2005 there was the Base, Limited & SRT-6. Below is the 2004 model year vin info from the service manual.
2 Make C = Chrysler
P = Crossfire (RHD)
6 - Export Transmission C = 6 Speed Manual (DED)
Old Jul 23, 2007 | 03:05 PM
paradiso's Avatar
Question Re: Vin # POSITION INTERPRETATION CODE = DESCRIPTION
Question:
"12 through 17 Sequence Number 6 Digit Sequential Number Assigned By Assembly Plant."
Does this number run in sequence from 000001 in 2004 thru xxxxxx in 2006/7 and does ones six digit number represent the total production number up to that vehicle?
Regards Larry Hegle # 068453
2006 Ltd Roadster
Aero Blue
Stock as delivered
Old Jul 23, 2007 | 03:19 PM
danimal's Avatar
That is the assumption.
Old Jul 23, 2007 | 04:49 PM
Display_Name's Avatar
I still don't understand why Crossfire VIN's begin with a "1".
I always thought that the first digit of the VIN was based upon the actual place of assembly, not based upon the country where the manufacturer was based.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
TOPLESS
Feb 9, 2016 11:28 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
Geechee1962
Sep 16, 2015 05:33 AM
bobbie
Sep 12, 2015 12:49 PM
