xfire makes a noise from cold
Old Aug 10, 2007 | 12:21 PM
dannyp's Avatar
Unhappy xfire makes a noise from cold
when i drive my xfire from cold, i drive alone and when i take my foot of the pedal the car makes a rattling noise. this noise goes when the car is warmed up. any ideas as my warranty has run out.
Old Aug 10, 2007 | 12:37 PM
RPM's Avatar
RPM
Moderator
Question Re: xfire makes a noise from cold
Do you have a SRT6 or n/a Crossfire?
Old Aug 10, 2007 | 12:38 PM
dannyp's Avatar
Default Re: xfire makes a noise from cold
standard crossfire, not an srt.
Old Aug 10, 2007 | 12:43 PM
danimal's Avatar
Possibly the catalytic converter. The guts may have come loose and rattle around on deceleration.
Old Aug 10, 2007 | 12:45 PM
dannyp's Avatar
it only does it when the car is cold, once it has warmed up no noise. if it is this can it be fixed or new cat.
Old Aug 10, 2007 | 12:47 PM
danimal's Avatar
The guts are probably expanding enough from heat to stop the rattle. Either 'gut' the cat or get a new one.
But make sure that is what it is first...I'm just making an educated guess here.
Old Aug 10, 2007 | 12:49 PM
danimal's Avatar
I was also just remembering something from a long ago post...it could also be a the heat shield above the muffler. At least that is easier to check.
Old Aug 10, 2007 | 03:52 PM
andrew's Avatar
-C-I-C-C-I Associate Member
if so... this should still be under warranty as it has to do with emissions.
IGot2P
Jul 26, 2025 12:40 PM
xfClifford
Mar 3, 2021 04:52 PM
Kodebuster
Nov 5, 2020 04:06 PM
Tp'sfury
Aug 13, 2015 08:20 PM
Buchacho
Aug 6, 2015 10:17 PM
