Lubricating hinges/latches
Old Sep 5, 2007 | 09:17 AM
thegoalie's Avatar
Angry Lubricating hinges/latches
Okay, so page 223 of the Xfire owners manual specifies which hinges and latches need to be lubricated, and with what lubricant. There are two types: Mopar white spray, and Mopar multipurpose lube with a bunch of letters/numbers after it. I was at the dealer yesterday for my $120 oil change and I stopped by the parts department to buy a spray can of both lubes.
First I used the Mopar white spray on the passenger door hinges/latches as specified in the owner's manual. They aren't kidding, that spray is WHITE. It looks like someone flung a tablespoon full of cool whip at every spot I lubricated. It's terrible. I was expecting the white to disappear over time, but it's just turned a sick yellowish now. After that, I halted the use of the white spray and continued with the multipurpose lube.
The multipurpose lube is clear, might better. I want to use the multipurpose lube for the spoiler and driver's side door now, even though the owner's manual specifically says to use the white spray.
Any thoughts?
Old Sep 5, 2007 | 09:32 AM
Fenwick223's Avatar
Default Re: Lubricating hinges/latches
I know that our XF's are "different" and everything about them seems to be "special" but when it comes to lubricating hinges and latches I can't believe that it makes one bit of difference. I use whatever can of gun oil that I happen to be using this season but I'm sure that good old 3 in 1 oil or a drop of Mobil 1 would do the job.
Old Sep 5, 2007 | 01:21 PM
radmanly's Avatar
The spoiler on my Limited squeaks from time to time. When it acts up, I put a dab of Permatex White Lithium Grease (#80345) on the joints. I got it at Autozone for less than $5. Works great.
Old Sep 5, 2007 | 03:15 PM
WD-40 has worked for years. A little every month and you are set.
Old Sep 5, 2007 | 07:25 PM
kurtisberry's Avatar
You can wipe off the extra spray white grease. Spray on, open and close the doors a few times and wipe off the rest. Very little actually gets into what needs to lubed. Any grease you can see isn't doing any thing and can be wiped off.
Fla_Xfire_SRT
Jun 29, 2015 06:51 PM
golfdude
Detail Shop
104
Jan 28, 2014 12:57 PM
